Need advice on thickness of metal to weld
   / Need advice on thickness of metal to weld #1
psient
Bronze Member
Hi:
Can anyone tell me: what is the thickest metal I should be able to SMAW weld (arc weld) with a 180 amp welder?
Thanks,
Jon
   / Need advice on thickness of metal to weld #2
That depends on the type of joint/ size of weld.
You can weld 3 inch plate with 120 amps- as long as you have beveled edges at the joint and make multiple passes.
Sure, it'll take a while, but it can be welded, and welded properly.
How much can 180 amps weld in a single pass ?
I suppose you could weld 1/2 plate, using 5/32 (or maybe 3/16) rod, at 180 amps-using no bevels and just a single pass, but even then your resulting weld won't carry the same load as the base material.
Thanks towmotor
I want to make a sub-soiler and I was thinking of using 1" plate for the tine. I would have to attach the tine to a yoke. I had thought the yoke would be 3/8".
Jon
2013 Chevy Silverado 2500 HD (A53472)
2013 Chevy...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
2014 Freightliner M2 106 Medium Duty Truck with Tool Bed, VIN # 1FVACWDT0EHFS2811 (A51572)
2014 Freightliner...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
