Need advice on replacing a few boards on my trailer , oak or pine
   / Need advice on replacing a few boards on my trailer , oak or pine #1
bm3
warsaw va
MF 1635 , JD 3203 , JD 1070
The boards are oak , 5 year old skid steer trailer and already 2 rotten boards. I have older trailers that are way more used with pine deck and zero rot . Would you find oak , 14ft 2x6 , or pine . Lowes does not have oak but either way probably have to find a mill. Why would Centerville Trailers use oak anyway ? Stronger? sure rotted fast
   / Need advice on replacing a few boards on my trailer , oak or pine #2
Why not go with ground contact rated pressure treated?
I mix 50/50 motor oil and diesel to treat my deck boards.
   / Need advice on replacing a few boards on my trailer , oak or pine #3
i'd go with PT and forget the environment poisoning diesel/hazardous waste oil treatment and instead put asphalt based fence paint on them.
   / Need advice on replacing a few boards on my trailer , oak or pine #4
Any treated wood will last forever, oak or rock maple wil only add weight. go with pine
I thought pressure treated would rust the steel. Manufacturer used motor oil to treat them , guess I should have redone them. If pressure treated is ok Lowes has that in my lenght
Pine sure is easier to find for me , probably my best bet then , thanks
   / Need advice on replacing a few boards on my trailer , oak or pine #7
plenty of things better and more legal than use dmotor oil to treat wood.
I will try the asphalt based fence paint , thanks for the info
   / Need advice on replacing a few boards on my trailer , oak or pine #9
i have a flatbed i bought in 2000 it had untreated (new) lumbe ron it when i got it. didn't make it to the 2nd year before boards rotted on it. I repalced with PT pine. painted them with a-f-paint.. both sides.. liberally. then installed them.
that wood is STILL on there. about 5ys ago I put an overlay of 3/4 marine plywood on it as I was hauling a trike a few times a month, and the trike had narrow , tall rears,a nd a single front.. and depending on how i loaded.. it always put alotta weight on not enough boards.. so the 3/4 plywood really spread it out good.
agian. that same wood is showing no signs of giving up soon.
   / Need advice on replacing a few boards on my trailer , oak or pine #10
Pretty sure OAK is used for the strength. Next time I'm in there I will ask them, Centreville manufacturing is 4 miles down the road from me.
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
Ruger Shop Crane, 2,000lb Capacity (A52384)
Ruger Shop Crane...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
45051 (A51694)
45051 (A51694)
Ford 4630 (A50123)
Ford 4630 (A50123)
