Need advice on how to fully replace fluid in the 4530 Hydraulics/Pwr Strg/Transmissio
   / Need advice on how to fully replace fluid in the 4530 Hydraulics/Pwr Strg/Transmissio #1
indigob
North Central TX
Mahindra 4530
Hi TBN,
I need to replace all the fluid in the whole shared
Hydraulics/Power Steering/Transmission system.
I am changing over to a multi-function hydraulic
fluid and want it to all be the same fluid through
out. Any suggestions on how to purge the old
fluid without burning the pump up or causing
it to cavitate?
Thanks,
Indigob
   / Need advice on how to fully replace fluid in the 4530 Hydraulics/Pwr Strg/Transmissio #2
I wouldn't try to purge the system. The original fluid in the system should be compatable with your replacement.
Thanks Galen,
It turns out that I didn't lose nearly as much fluid as I thought.
After replacing the power steering line and checked the level
while running, it was still within acceptable levels, then
bled the air out by cutting the wheels back and forth.
I have seen many of your posts on TBN and very much appreciate
your involvement and advice (with obvious expert knowledge)!
Sincerely,
indigob
   / Need advice on how to fully replace fluid in the 4530 Hydraulics/Pwr Strg/Transmissio #4
What is the proper way to check the transmission/hydraulic fluid on the 4530? Engine running or stopped? It's not mentioned in the owners manual.
Hi Kbaer,
The transmission dipstick is on the left side near and a little
below the clutch (left side as you are sitting on the tractor).
The dipstick is a grey and about 4 inches long bolt head.
The service manual says to check the level while the tractor
is running. Be sure brush away as much dirt and dust before
removing the dipstick.
Indigob
2009 Ford Econoline E-350 Cargo Van (A50323)
2009 Ford...
Kubota SVL97-2 (A50120)
Kubota SVL97-2...
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
2016 Chrysler Town and Country (A50515)
2016 Chrysler Town...
Case IH 7120 Combine (A50514)
Case IH 7120...
