newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,096
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Need advice for "low voltage lighting" and wireless camera setup 12VAC to 5VDC
I've a tree lined driveway that's about 80' of DARK between my house and workshops. We've a couple of high output street lights we "rent" from the power company that light up most of the yards but this stretch is DARK on summer nights. And the concrete drive has proved itself to be an area copperheads and other snakes like to lay on at night.
I've got a 120V outlet at one end and was thinking of putting in some low voltage lights activated by motion sensors. I would probably arrange them in the trees or on poles to light the path. At the same time I would like to put in some Wyze cams to monitor who is coming up the drive.
The lighting power is nominally transformed from 120VAC to 12VAC, the Wyze cams run off USB, which is 5 volt DC.
I able to find a lot of references on running the low voltage lighting but very limited info on going from 12VAC to 5VDC. I might just be using the wrong search terms.
Any pointers?
I'd like to keep the per unit cost < $20.
Any pointers?
