pharmvet
Platinum Member
- Joined
- Sep 28, 2008
- Messages
- 533
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Ok, my 2002 ft water line is well underway and I need to finish it tomorrow. All trenches are dug and difficult plumbint (T's and detail work) completed. All I need to do is connect the pvc (2" slip joint), drop it in the trench and cover. Here is my delima:
The male ends of the pipe have a mark encircling them. The mark is 3-1/2 inches from the end which has a bevel making it easier to slide up into the female end with the gasket. We were told to use food grade lubricant and it is working well. If I slip the male end into the female end to the mark, there is still about an inch that I can push it on further in. With everything that is within me, I desperately want to push it in until it bottoms out. However, I suspect this mark is there for a reason, and I suspect the reason is to allow the pipe to slip either direction.
When fitting this type of pipe do you
a) push it in until it bottoms out
or
b) push it in only to the mark to allow for expansion either direction
I want to do this right and only one time. Please, please, please someone who really knows how this pipe was designed to be used tell me what to do. thanks a million.
or
