need a little more hyd flow
   / need a little more hyd flow #1
Harold B
I have got a LK 2554 and the hydraulics all check out good with a flow rater and pressure. I am looking for a few more gpm.
Is the LK 3054 pump shaft the same diameter and spline?
Is the mounting bolt pattern the same?
I am not too worried about the inlet and outlet porting, i can fab these to fit.
Now, beforew we go into the flow/heat issue, please don't bother with that.
I work on heavy equipment and have a very sound understanding of hydraulics and hp requirements, pressure compensated valving, radial and axial piston hst pumps, closed and open center systems etc...
If someone can count the splines and measure the diameter of the shaft and also measure the mounting dimensions, i would greatly appreciate it.
Thanks everyone
   / need a little more hyd flow #2
I bet if you call kioti and ask for technical assistance they may be able to tell you interchangeability.
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2012 John Deere 7230R (A52748)
2012 John Deere...
Cummins Onan 35EK (A47384)
Cummins Onan 35EK...
2004 Chevy 1500 Pick Up (A50515)
2004 Chevy 1500...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
