need a disc for tc40a
   / need a disc for tc40a #1
docjon
Coweta, ok
kubota M7040 with FEL
any good recommendations for a disc for tc40a, thinking about 6' king cutter any other companies make a good product and can I use a bigger disc than 6'?
   / need a disc for tc40a #2
jbrumberg posted a photo with several recommended attachments for the Boomers, http://www.tractorbynet.com/forums/nh-buying-pricing/102498-looking-boomer-specs.html#post1166152.
There was no mention of discs or plow in the brochure, but it does say your TC40A can take an 80" HD Rotary Tiller. Obviously, the conditions of your soil and terrain will affect what you can really pull with your tractor.
OBTW, KK and Woods make very good equipment.
Hope this helps a little.
   / need a disc for tc40a #3
An old ford N will tote a 5-6-6.6' disc.
I'd say your 40 will drag it all over the place.
If you had a transport disc.. It'd probably pull an 8.
Depends on dangs and angle.. and weight of construction.. and ballast.. and soil type.. and yer tires.. all things considered.. etc.. Size of gates on the property.. etc..
Soundguy
   / need a disc for tc40a #4
Soundguy
I agree. I actually pull the same 6' disc that I used with my 8N with my TC40DA. You won't know a 6' disc is behind you.
   / need a disc for tc40a #5
Got any pics of that lowboy?
I got a 66 cub..love that thing.. kinda like a lawnmower on steroids..
Soundguy
   / need a disc for tc40a #6
Get the heaviest one you can afford. I bought a 6' KK angle frame disc. I figured I wasn't going to use it that often so I opted for the angle frame over the heavy duty tube frame model. I should have bought the HD. I have at least 200lbs of weigth strapped on my disc at all times to get it to cut in like it should. It works fine that way but the loose weights are a pain, and difficult to keep distributed on the disc frame so it doesn't stress it too much.
Overall the KK works fine for me. Don't forget to get a couple tubes of grease when you buy one so you can fill the bearings.
2016 Chrysler 300s (A51694)
2016 Chrysler 300s...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
