Need a cheap small pump for used oil
   / Need a cheap small pump for used oil #1
bdog
Elite Member
Texas
John Deere 6130M
We have a lift and most things get the oil changed on the lift and drained into a 25 gallon rolling drain pan that has an air fitting to pump the oil out and into a bulk container we have. We do have some things like the semi or dump truck which won't fit in the lift. I bought a 15 gallon Rubbermaid feed trough from tractor supply and changed the oil in the dump truck today. It is within an couple inches of the top and heavy. I can't see how I will pick it up and dump it without making a huge mess. I guess I could scoop it out in smaller buckets but that will be messy also.
Are there any cheap pumps I could use to pump this oil from the 15 gallon pan on the floor up into the top of a bulk container about 4' off the ground? Doesn't have to be fast this will be done about 4-5 times a year.
   / Need a cheap small pump for used oil #3
maybe a cheap HF fluid pump will work for you.
5 Gallon Oil Pump
I've a similar one I use for diesel, for which it works well.
It may not handle oil due to viscosity.
/edit -
Reread the description more carefully - I agree w/ Foster - it would take about 400 strokes for 5 gallons.
   / Need a cheap small pump for used oil #5
It won't be quick to purchase, but there are plans/youtube videos on how to make one from a small block chevy oil pump. They can be driven with a cordless drill making it very portable. I have the parts to make one myself, which has been a work in progress that has been put on the back burner for quite a while , due to other priorities.
   / Need a cheap small pump for used oil #6
Maybe try a submersible fountain pump from HF, one's on sale now for $9. A lot cheaper than the waste oil transfer pump on Surplus Center.
Don't know how the plastic would stand up in oil, but I'd be tempted to try it, and then put it in a bucket of water to flush for a while.
   / Need a cheap small pump for used oil #7
   / Need a cheap small pump for used oil #8
   / Need a cheap small pump for used oil #9
Well for cheap if being intrinsically safe is not an issue one of those inexpensive electric hand drill pumps would serve you well. Probaly cost twenty bucks or less. Attach it to a battery operated drill and it gets portable.
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
2018 KUBOTA SVL95-2 SKID STEER (A52705)
2018 KUBOTA...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
72'' power rake (A53421)
72'' power rake...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
