Backhoe need a backhoe
   / need a backhoe #1
BWS
seattle area
kubota l3830 hst/723 fel
got a deal on a great bend 752 3pt mnt no pump for 5300.00 and 6300.00 for frame mnt.both these would be plumbed into tractor.is a woods 7500 better?different dealer wants 5500.00 for a frame mnt woods7500.what do you think??any recomendations?
   / need a backhoe #2
I don't know about the Great bend but the
Woods 7500 has a chain and cylinder set-up
to swing boom.
I had a 7500 and traded up to a 9000 later
from an individual (this has 2 cylinders on swing).
Woods is real easy to get parts or info
from, I had to get new mount for the 9000 to
my SSL.
   / need a backhoe
the woods 7500 uses a swing chain??the g.b.doesnt maybe the g.b.752 would be better??
   / need a backhoe #4
Yes it uses a swing chain,I didn't have any
problems w/ it in 4yrs. I had it.
   / need a backhoe #5
In the 70's I had a small hoe with chain swing. Had to keep my toolbox full of master links for it. Would never have onother one designed that way.
   / need a backhoe #8
I recently bought a Bush Hog 765. The reason that I went with it was the specs on it were greater that the Woods 7500, and it has 2 swing cylinders. I have been very happy with this unit. I got it with the subframe and separate PTO Pump. I have wanted one of these since I was about 10 Years old /w3tcompact/icons/smile.gif. I finally got it. I said to myself how much longer should I have to wait. I crushed a disk in my back that required back surgery to correct, and I need to start working smarter, not like an animal (like the way I used to), if you know what I mean.....
   / need a backhoe
how much was it?the bradco 3375 3pt seems very reasonable @ 3500-4k$ same specs[almost] as the g.b.752.searched on this site and dont see any posts on this?
   / need a backhoe #10
I almost did'nt get the Woods 7500 because of the chain swing mechanism. /w3tcompact/icons/hmm.gif Talked to dealer , he said they had no problems at all with the chains and a friend who had one for 8 yrs. said the same. I went with the Woods on good faith and I really have worked it hard for 200 hrs /w3tcompact/icons/tongue.gif. so far, without a problem. The 16''bucket, that I have is made by Gannon and it 's one tough unit and very well designed. with HD replaceable teeth./w3tcompact/icons/love.gif I would recommend it highly. ..RayBee PS. ( You did'nt mention what tractor you were mating to this BH) ..but I would also recommend the subframe unit over the 3PT. ..Safer!
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
2014 Dodge 5500 4X4 Bucket Truck (A53473)
2014 Dodge 5500...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
2015 Ford F-450 Bucket Truck (A53117)
2015 Ford F-450...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
