Ned a hydraulic Adpter block for Case 235
   / Ned a hydraulic Adpter block for Case 235 #1
Mikkos
Winnipeg
Case 235
I have been looking for a Hydraulic adapter block for a Case IH 235 Tractor. It is not made anymore apparently band I cannpt seem to locate one. I have a need to add auxiliary hydraulics to the tractor. I should have done a little more investigating before I bought it. If anyone knows of another way to tie into the hydraulics or know of a Adapter block or someone who has a drawing of one steer me in there direction please.
Case 235
Hydraulic Adapter block P# 1288347C1
Thanks for any help you can offer
   / Ned a hydraulic Adpter block for Case 235 #2
I know I tried them as well, they said they have no access to the part anymore. Thank you for your quick response though.
Mike
   / Ned a hydraulic Adpter block for Case 235 #4
What is it?
I have a part I am removing from my NH loader that all loader hose go in and out of.
Is that it?
What is it?
Is that it?
Thank you but no it is a hydraulic adapter block that mount to the Hydrostatic gear case to give you the option of additional Hydraulic ports to add controls to.
Thanks Anyway
   / Ned a hydraulic Adpter block for Case 235 #6
Mike
Well Shucks. I was hoping that would be the magic bullet.
I did find a schematic that at least shows everyone the part you're looking for but it didn't put me any closer to finding the actual part.
Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
I guessing you already tried Antique Tractors - Yesterday's Tractors : Parts and Online Community
I couldn't find anything but maybe a call to thme might have some leads?
Looks like a needle in a haystack - I wish you much luck in your search.
   / Ned a hydraulic Adpter block for Case 235 #7
Case 235
I am in need of one as well and have decided I will have to make it. I can make one for you also if you are interested (would have to charge for the time and materiel). You could also split the hydraulic pressure line (the small line running along the top of the transmission case) and run it through your loader valve and back into the pressure line. This is a less than ideal solution but it will work. You can use pressure fittings to tie into the hard line (it is a metric line). If you are just planning on an auxiliary you can still split the line but you have to mount the spool valve, you cant just dead head the lines.
Do you already have a drawing for it? If you do I could make it as well. I have not had time to access mine and make a drawing.
Mike
   / Ned a hydraulic Adpter block for Case 235 #9
I have a international 254 made by mitibushi that I used these hydraulic fittings to give me aux hydraulics.
My hydraulic pump has 4 bolts holding a steel flange onto the pump, you will need two flanges and two orings the flanges are drilled for bolt on and threaded for 3/8 sae pipe. This site will not let me post a link because I have not posted enough yet. LOL
Hoye tractor, and look for generic hydraulic fitting. This site is for yanmar but the flange fit my mitibushi perfectly.
Hoyetractor.com
   / Ned a hydraulic Adpter block for Case 235 #10
Im in need of an adapter could you make me one? also if so how much would it cost?
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2020 CASE IH 110N LOT NUMBER 241 (A53084)
2020 CASE IH 110N...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
