KYErik
Platinum Member
- Joined
- Dec 2, 2005
- Messages
- 904
- Location
- South central IL
- Tractor
- 1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I recently bought a 1960's era 4cyl gas Ford 4000. I love everything about this tractor except the steering.... Even with no front weights, the steering wheel is quite difficult to turn and the turning radius seems huge (my old tractor was a 1940's Case SC- tricycle type).
Right now, the adjustable front axle is set at about 68 inches (rears are at 72 inches), but my owners manual shows how I can narrow the front end to a minimum of 52 inches.
Would narrowing the front by 16 inches noticeably improve the turning radius?
Might it also reduce the effort required for steering or is this likely just a function of the gear ratio of the steering box?
Note: there are only gentle hills here so rolling over isn't an issue (I had no stability problems with my old tricycle tractor).
