Narrow my 1981 Massey 255
   / Narrow my 1981 Massey 255 #1
lhengst
Massey Furgeson 255
Very ignorant and new tractor owner here. I leveraged the expertise of my multigenerational farming friend to help me find an inexpensive tractor that needed some work. Last night I purchased a 1981 Massey 255 with a front loader that needs a new clutch.
The 255 is wider than I had ideally hoped for. She barely won't fit on my trailer, she will be a tight squeeze through my fence gates, and I have some roads cut through the woods that she won't fit through without me widening the roads.
Is it a good idea to put smaller and narrower tires on her?
She won't be used for any row cropping, just brush clearing, augering, road building, etc. I do have some steep slopes on my property that she will need to safely navigate.
I figure narrower tires will make the tractor more prone to rolling over. But, if I also get lower diameter tires, that should lower my center of gravity and offset the rollover risks of narrow tires.
   / Narrow my 1981 Massey 255 #3
Find a manual, chances are you can change the width of the tractor by simply changing how the tires are mounted or post a pic of the tires and rims so folks can see what type of rims it has and thus give you more options.
   / Narrow my 1981 Massey 255 #4
Exactly right. You should be able to change the tire width using what you have. MF ag tractors had a lot of width adjustability built in. Did you get the operator manual with it? The op manual will show how - and maybe you can find one online.
That is much easier than changing tires - which often requires changing wheels - and that is difficult on these models if it has the type of hub and rim I think it does.
Which engine does it have? Gas or diesel?
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2005 DRAGON  130BBL VACUUM TRAILER (A52472)
2005 DRAGON...
