Tiller Nardi Rototiller Question
   / Nardi Rototiller Question #1
Erik Graham
Bronze Member
Toronto, Ontario
Kubota B2630,Ford NAA, Kubota L2550GST
Greetings;
I am looking into purchasing a Nardi Rototiller-58" for use with 30 hp 4wd tractor. One of the ads I looked at suggests that the tiller is available with either "C" or "L" tines. I can image what the shape of the tines would be but not clear on the use or advantage of one over the other might be. Primary use would be on pasture that has been plowed, with a mind to create a market garden. Any advice or insights greatly appreciated.
Thanks, Erik
   / Nardi Rototiller Question #2
rototiller
Greetings;
Thanks, Erik
all depends on your soil and how well it allows hacking and wacking at it.
The C tine is a slasher tine with a narrow slashing width and the L tines cut and shred a wider portion breaking more ground area with fewer tines
which consumes more power please read below tomake your life easier- it will also allow you to make use of a soil bedder/plastic layer with much less work to keep weeds out.
www.buctraco.com soil bedders/plastic layers, vegetable transplant planters
If it were me:
I would buy a modern brand one bottom plow and replace the plow share with the weiss industries 14 inch deep replacement plow share
(deep conservation tillage) which will suck down to 14 inches and the moldboard has very little resistance in the soil as it has a narrow cut angle which allows it to zip through the ground. This eliminates all the hardpan everytime every year and the landpride RTR will be an even better tiller with the Weiss deep conservation plowshare and the Duragrade A1 rock picker
the land pride RTR rear tine rotation tiller will be a better tiller as it will suck itself into the ground and stay there and you could use the A1 rock picker offered by www.duragrade.com to pull al the rocks after you till with very little hand labor.
www.duragrade.com
www.landpride.com
2005 Pierce Enforcer Special Operations Fire Truck (A50323)
2005 Pierce...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A52141)
2018 PETERBILT 579...
Gehl Mix-All Mill (A50515)
Gehl Mix-All Mill...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
