NAPA hydraulic/transmission fluid
   / NAPA hydraulic/transmission fluid #1
j845125
Does anyone know who makes this stuff for NAPA? Has anyone used it in there tractor? All the bucket says is made for Balkamp.
   / NAPA hydraulic/transmission fluid #2
I've used it for more than 35 years. At one point, I used to buy it in 55 gal drums. Never had the first sign of problems. I've used it in Massey's, Deere's, and Fords. I was told several years ago NAPA will contract with any one of several oil companies to supply their oil. So long as it meets or exceeds standards, it's good stuff. Last time I asked, I was told their hydro oil was refined by the same people who market Castrol motor oil.
   / NAPA hydraulic/transmission fluid #3
It isn't who makes it as much as who set the standards for it! There are many companies that blend the oil for retailers to put their label on. We have a NAPA right next door and they refer me to their other blends for my cars for quality.
Here in NY for hydraulic fluid we do recommend the Hytran oils from Case because of the amount of water they can absorb. We have varied temps thru out the year which gives us a lot of condensation in gear cases and that oil can absorb more then the other oils we tested against. This saves pump starvation when things are frozen.
   / NAPA hydraulic/transmission fluid #4
NAPA used to get all their lubricants from Ashland/valvoline
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A52377)
Gravely Pro-Turn...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
20702 (A51694)
20702 (A51694)
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
