NAA Replacement Radiator
   / NAA Replacement Radiator #1
MH49
Ohio
CASE IH 5220; Cockshutt 570 (2x); Massey Harris 44; Ford NAA; 1872 Super Cub; MF 14, 12 and 10 Garden Tractors
I need to replace the radiator on my NAA. Does anybody have any recommendations on a source? This is a working tractor so I want something that is decent quality. Thanks.
   / NAA Replacement Radiator #2
Im not sure what model ford tractor it was for ( probably an 8n ) but my local TSC has one on the shelf .
might check with them or Agri supply .
C-ya
Scott
   / NAA Replacement Radiator #3
are your tanks good enough to simply have it re cored? if so.. use an industrial core.. recore means you know the inlet and outlet will be in the correct place!
After much debate, I oppted for an aftermarket one from my local NH dealer mainly because he had it on the shelf. I really didn't want to recore the stock one because I have not had good success with that in the past. Quality (its from TISCO) seems to be ok but the stock screws that hold the fan shroud on were too small so I had to dig up some different ones. I hope to finish up the installation tonight so we will see.
Thanks to everyone for the input.
   / NAA Replacement Radiator #6
good luck.
in the end if the hold downs are fititng and the hoses are inthe correct palce.. that's usually most of it.
problem is some repops have a small core / less tubes / small tubes and are not as efficient. on a 32hp engine.. may not be a big deal..
good luck
   / NAA Replacement Radiator #7
I put a ebay repop on my 871 (naa style) and it works fine. 140 bucks. Screws didn't work like you said. Temp never gets over 170.
   / NAA Replacement Radiator #8
yep.. the hold downs almost never fit.. :)
   / NAA Replacement Radiator #10
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
Caterpillar 262 B 4 Tires Solid with Rims (A53117)
Caterpillar 262 B...
Miller Dimension 452 Welding Machine (A53117)
Miller Dimension...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
2019 KENWORTH W900 DAY CAB (A53843)
2019 KENWORTH W900...
