Mystery. Utterly baffled.
   / Mystery. Utterly baffled. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I have a 12 year old Kubota L4400. I'm pretty familiar with every inch of this tractor. Yesterday I had to replace the fuel gauge sending unit in the fuel tank. An easy job.
I open the hood as usual. No problem. When I go to close the hood, the hole in the hood that surrounds the fuel tank filler cap catches on the back edge of the filler cap and will not close. Remove cap. Close hood. Replace cap. A little later, after removing and reinstalling the whole hood assembly (which I've done a dozen times) it will not open or close without catching on the filler cap.
Everything is aligned normally. With the filler cap off it opens, closes, latches and unlatches and lines up perfectly all the way around just as it always did. The hinge pins are welded onto the tractor over and behind the fuel tank. The hinge holes on the hood also appear fixed in place (but it occurs to me now that maybe they are bolted on and have gotten loose, but I did not notice it at the time). The fuel tank is firmly in place. I have removed it before but that was over a year ago and no problem with the hood until now.
My tractor is on my property an hour from here. So is the shop manual. Does anyone know if the hood hinge holes on a typical Kubota are bolted to the hood? If so, that has to be the problem and I just overlooked it. If not, I cannot imagine what the problem is.
   / Mystery. Utterly baffled. #2
Did you have to loosen or remove the tank? The only thing I can think of is that the tank is sitting a little higher causing clearance issues in the hood arc.
No. Did not move the tank. Found some parts diagrams online and it looks like the hinge holes on the hood are also welded on. So there isn't anything that could be out of adjustment.
   / Mystery. Utterly baffled. #4
Maybe something keeping the fuel cap from screwing all the way down? Rigid gasket got crooked or something.
   / Mystery. Utterly baffled. #5
The tank is probably sitting on a cradle and held in place with straps.
Either the straps have snapped allowing the tank to slide forward or backwards or accumulated oils have rendered the area slippery.
Generally a tank sits on felt or rubber strips to prevent abrasion.
   / Mystery. Utterly baffled. #6
Not likely, but is the cap screwed on crooked?
   / Mystery. Utterly baffled. #7
If you lift the front of the hood by hand, beyond the distance required to set the holding mechanism you can bend the hinges which moves the hood forward when closed. Don't ask how I know. ;)
   / Mystery. Utterly baffled. #8
I can't help, but I'll be watching closely. Over the years, my 2006 Kioti DK45 has developed a similar issue. In my case, the fuel hatch cover hinges hit the fuel cap. This means that I have to open the hood slightly to open the hatch cover on the hood, then close it to remove the fuel cap and refuel, then replace the fuel cap and open the hood again to close the hatch cover. Refueling is enough of a hassle as-is; this makes it even more irritating.
Like N80's Kubota, my Kioti doesn't seem to have adjustments for re-positioning the hood or fuel tank.
Bob
   / Mystery. Utterly baffled. #9
Once you analyze what's going on, remove the hood and bend appropriately. :)
Thanks Richard. I'll give it a look but I'm a little worried that if I start bending things to make it fit the fuel cap then something else won't line up. Now, as long as it opens, closes and latches I don't care about much else.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
CATERPILLAR D3K2...
1043 (A50459)
1043 (A50459)
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
