MY2012 5085M ordered today!
   / MY2012 5085M ordered today! #1
pclausen
Veteran Member
Nelson County, VA
JD 5085M, Ford 1700, JD GT235
So I finally took the plunge and got a factory fresh 2012 5085M on the way.
It will be equipped with the following factory options:
  • MFWD (4 Wheel Drive)
  • Deluxe Cab
  • Instructional Seat
  • Deluxe Corner Post Exhaust
  • 16F/16R PowrReverser Transmission - 540/540E
  • Electrohydraulic (EH) with remote LH fender control
  • Triple Rear Deluxe Valve with Lever Controls
  • Triple Mid Valve with Joystick Control
  • 420/85 R34 R1W Radial (Michelin Agribib)
  • 13.6R24 125A8 R1W Radial (Michelin Agribib)
  • 63mm Hitch Lift Cylinders
  • High Capacity Fuel Tank
  • Front Weight Support
  • Cold Weather Package
And I'm picking up the following "dealer attachments" that I will be installing myself:
  • Rear Fender Extension Kit
  • Electrohydraulic (EH) Hitch Right Fender Switch Kit
  • Oil Collection System
  • Auxiliary Work Light Kit (2x)
  • Brake Light Kit
  • PowrReverser Modulation Control Kit
  • Service Horn
And it will have a loader that will be configured as follows:
  • H260 Standard Loader
  • Mounting Frame
  • Mechanical Self-Leveling - 3-Function
  • 3-Function Hoses and Parts
  • 3-Function Single Point Hydraulic Connection
  • Hood Guard
  • Large Ballast Box
  • Global Carrier
  • 1850 MM (73 In.) Global Heavy Duty Bucket
And last but not least, it will come with the following attachments:
  • Woods SG100 Stump Grinder
  • Bush Hog 3209 Rotary Cutter
  • Frontier AV20G Root Grapple 77"
  • CB Pallet Forks
I opted not to get the side mirrors and will instead get a rear camera with a monitor.
I also will start out with no liquid ballast in the rears and see how things work out. The larger ballast box filled with Portland Cement should help with grapple/loader work. I want to run light footed for moving duties, taking advantage of the radials. If conditions warrant, I'll add rear weights (loader/grapple work), front weights (Bush Hog 3209 work), and as a last resort, liquid ballast (16-3 plow work?).
I'm excited!
   / MY2012 5085M ordered today! #2
Excellent looking build!
This looks like the best build for what you've described:thumbsup:
   / MY2012 5085M ordered today! #3
  • Deluxe Cab
  • Brake Light Kit
  • Service Horn
  • Mounting Frame
  • Hood Guard
  • Large Ballast Box
  • Global Carrier
  • CB Pallet Forks
I also will start out with no liquid ballast in the rears and see how things work out. The larger ballast box filled with Portland Cement should help with grapple/loader work, and want to take advantage the the fact that I'm running radials.
I'm excited!
Congrats! I think were both like children on Christmas Eve now! 6430 Premium for me 5085M for you, Everyone Happy! :laughing:
   / MY2012 5085M ordered today! #4
Congratulations! I really think you'll be pleased with the M. Excellent option layout, too. :thumbsup:
AKfish
Appreciate the encouragement. You guys are a lot more excited about this than my wife. :laughing:
I'm also picking up a Woods RB850 3-way hydraulic blade (found used on Craigslist w/ 2 way hydraulics, I'll be adding the 3rd), and a Woods LR108-2 rake (used on tractorhouse.com).
   / MY2012 5085M ordered today! #7
Very nice! I think you are going to be very happy with that tractor!
I did a lot of vacillating myself about the RimGuard, but in the end I did what you have done, I went with no RimGuard to maximize the ride and footprint of the radials. I've got two hundred lbs. of wheel weights per side and the small ballast box on the way.
Do you know what the weights of the two ballast box options are when filled with cement?
Looks like a nice unit. What is the oil collection system?
It collects the hydraulic oil "drips" you typically experience when connecting/disconnecting the hydraulic lines from the rear remotes.
I believe the "small" ballast box (which I currently have) is about 1014# filled with Portland cement. The "large" ballast box appears to be at least twice the volume, so maybe 2000#+ filled with Portland?
   / MY2012 5085M ordered today! #10
Never would have guessed!! :laughing:
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
1,000 Gallon Horizontal Fuel Storage Tank with Pump - Farm or Construction Ready (A51039)
1,000 Gallon...
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
Pull-Behind Ripper Attachment (A49461)
Pull-Behind Ripper...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
