Loader My wife said I had a few screws loose
   / My wife said I had a few screws loose #1
Msamt
Enfield, NH
Kioti Dk45SE
I shoulda listened to her, 2 of the loader bolts were gone and another was stripped inside of the loader. Going to have to tap that one out I guess. Anyone know the torque spec for those on the KL401without looking?
   / My wife said I had a few screws loose #2
I have the smaller KL130 and the bolts are probably smaller too so no torque specs to help you. The one thing you can do and some dealers use it when installing the loader is to use blue loctite on the bolts. I'd take out the others and loctite them. I still put a socket on mine everytime I do service just to check but haven't had any come lose since using loctite. If you tap the hole bigger and wanted to stay with the factory bolt size, you could try a heli-coil. Just a thought. That same thing happened to a friends DK40 and the heli-coil worked fine.
   / My wife said I had a few screws loose #3
The manual that came with your tractor and loader has the info you seek.
   / My wife said I had a few screws loose #4
One of mine broke off a few years ago. It removes real easy after shearing. Dont remember torques, but its in manual.
   / My wife said I had a few screws loose #5
I just checked the manual for my KL451, which is the self-leveling loader for a DH45s. It says the bolts are size M14 but refers to a generic torque chart. That chart says (for M14) 106-127 ft lb for grade 8.8 bolts and 149-179 fy lb for grade 10.7 bolts.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
197711 (A51244)
197711 (A51244)
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2019 TAKEUCHI TB290 EXCAVATOR (A51246)
2019 TAKEUCHI...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
