My very own grapples!
   / My very own grapples! #1
Mrs3RRL
Bronze Member
You may remember back in December last year when I started to build my very own grapples for Honey Bee. Rob had designed a very cool looking set of grapples for Larry and Ken and I wanted a set too. So Larry got them Plasma cut for me and sent them out. I was so excited to get them.
Look what he sent me. Aren't they beautiful?
I'll try to describe what I had to do to make them.
First, I had to open up the holes that were plasma cut, so they'd be 'perfect' (don't forget who I'm married to ;)) Boy, now I know what Rob means when he says it takes longer to set up than it does to do the actual cutting.
The first step was clamping the work down. I used 1-2-3 blocks to set the work up high enough that I wouldn't bore a hole through the table.
Since there were multiple pieces, I also had to make sure that the part that was going to be seated was perfectly even. I used a 'perfectly' squared up piece of steel for that.
Then I clamped it to the table, being careful to keep the clamps and the 1-2-3 blocks out of the way of the holes.
Then I had to indicate the work in. I clamped the indicator onto the spindle, and Rob showed me how to make sure the hole was perfectly centered (notice the continued use of the word 'perfect'... remember who I'm married to).
Boy, there sure are a lot of levers and dials to remember! I'd get one side on zero (or close to it), then spin it around to the other side, and move the table so the work was half-way between zero and whatever the dial said. Then, go back to the first side, and to it again. Once it was centered side-to-side, then do the same thing front-to-back.
Since the holes had been plasma cut, they had a taper on the inside of the holes, and some gouges, so it was hard to indicate it in. But finally it was centered. Rob put the boring bit in, because I wasn't tall enough to reach the top of the mill.
Then we had to make sure the bit was set to the right diameter. Rob did that part, and Rob showed me which direction to turn the 'on' switch. That was pretty weird, because you turn it a different direction, depending on whether it's on high or low. I still don't understand that part.
Then I lowered the bit almost down to the work, turned the machine on, and engaged the part that automatically lowers the boring bit (I forgot what that's called). Wow! That made it really shiny! It's not completely shiny all the way around, because the holes weren't really round in the first place..... but they sure look pretty!
And I did most of it myself! I did the rest of the parts, too, and Rob took some pictures.
So, now that I've got the hang of it, I thought I'd help Ken (quikduk) out a little. He brought his grapples over here, and asked Rob to make some lightening holes in them and put them together.
First, I took my grapples as a model, and drew circles in the lightening holes on Ken's grapples.
Then, I found the center of each of the holes, and wrote down the coordinates, so I could always find the center. I started with a tiny drill bit, and then used progressively larger bits to enlarge the holes.
In this next photo, I'm checking the coordinates to make sure I'm exactly on center. The digital readout goes to 10,000th of an inch, but I just positioned to 1,000th of an inch (sorry, Ken .. I guess it's not 'perfect'):rolleyes:
After that, it's just a matter of lowering the drill bit into the steel, letting it do it's thing, and then bringing it out every once in a while, to get rid of the shavings... oops, I mean 'chips'.
Here's Ken's grapples, with all the lightening holes completed! That was fun!
Hey, Ken - Want me to weld them up for you, too??? :D
Well, I got pretty busy so Rob took over to finish up Ken's grapples.
These are some pictures of his while Rob was welding them up. I kept a close eye on how he set them up so I can weld mine just like that.
Ken's grapples are done now ready for him to paint. I could get back on my very own grapples again. I had to mill some sides square on the protector plate and make them the same length as the cross tubes so that everything fits when we weld it up.
I also decided to add some more lightning holes and to make them look special.:D
Gee, Rob's milling machine is bigger than me!
   / My very own grapples! #5
Loretta
Will Rob's next therad be how to cook a turkey dinner?
I'v tought all my childrein (3 daughters and a son) how to do basic engine work its it great you are rounding out your skills.
Just dont let him near the dish washer.
tommu
   / My very own grapples! #6
Loretta's grapples have already been welded together, so this is catching up a bit.
During the project she got pretty busy so she left some of the grunt work up to me like clamping and welding them. lol ... I suppose she wants me to sweep up the chips too?:confused:
She wanted to post these photos but couldn't find them (because I have them). I told her I'd post them for her since it's a good chance to get my post count up.:D This is what hers look like. Several guys have asked about them already. But anyway, here are a couple shots of her welded up grapples now, and some close up of the better AC stick welds. The grapples need to be cleaned up, then they are ready to prime.
I am very happy to see her take such an interest in her Jinma and making/doing a lot of the mods herself. There will be a few things I'll help her with, but she wants to do as much herself as time allows. She still works full time.
   / My very own grapples! #7
Looking good Loretta!
(That second picture tho...you with the claw...kinda creepy)
Gotta run now...need to check the other thread & see if Rob has written anything about the second shop going up. :D
tommu56 said:
Loretta
tommu
Hi tommu, thank you. funny what you said about Rob.
Some of his machinery is sooo big, I need a step stool to change the bits. I have a lot to learn before I can do it all myself, but he's pretty good about teaching me.
I read what you told him to do with the dishwasher too, how dare you? :D
   / My very own grapples! #9
I was thinking the same thing. Only us tractor guys would understand and appreciate this picture.
I truely enjoy Loretta's posts......almost as much as (if not more than :rolleyes: ) Rob's. :D :cool: :eek:
What was that about the dishwasher?
Don
when Rob was making his training wheels, he had one brand new, clean wheel, and one old grubby wheel, and he told Rob to put it in the dishwasher!
(hmm.. maybe THAT's why my dishwasher has suddenly quit working):eek:
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
3in Poly Pipe (A49461)
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
