my tc45 won't start
   / my tc45 won't start #1
Jeff krone
My tc 45 isn't getting any power to the fuel shut off switch, if I unscrew it from the injector pump the tractor starts right up, I get no warning lights on the dash and the fuse for the safety switch is fine
   / my tc45 won't start #2
   / my tc45 won't start #3
I posted two schematics in the thread Chris linked. The second one is the one you'll need to troubleshoot your problem. There are four things to check:
1. Seat Safety Switch
2. Operator Safety Module
3. Fuel Shutoff Relay (K5)
4. Fuel Shutoff Solenoid
First, as Chris suggested, try to power the solenoid with a jumper to see that it does work. Then, start looking at the seat switch. If those things don't show as bad, you'll need to take the cowling off under the steering wheel and troubleshoot the relay assembly under the left-side cowling. Your thread title says, "tc45." If you have the gear model, there is a different layout of relays. Let me know which model you have and I'll try to provide you a relay diagram so you can check relay K5 and the Safety Module.
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
2006 Chevrolet Express 2500 Cargo Van (A51692)
2006 Chevrolet...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
