My ROPS is hitting My Fender!
   / My ROPS is hitting My Fender! #1
Fleagle
North Texas
Kubota L3130
I'm new here and new to my L3130. I'm glad I found this place!
I only have about 11 hours on the tractor mainly using the FEL and a box blade.
Today I noticed that the ROPS was rubbing against the left fender as I was working. After shutting down, I noticed that the ROPS wasn't centered between the fenders with a large gap on one side and no gap on the other. Nothing seems unusual about the ROPS other than what I described. It could have always been like this, but I haven't noticed.
Is it normal to flex like this, or is my tractor bent?
   / My ROPS is hitting My Fender! #2
I have a KIOTI and my ROPS was just barely rubbing the left fender. I hope that your tractor isn't flexing to cause this problem, but you may want to contact your dealer to see if something is loose or bent. I made a small adjustment and all is fine but, just to be sure, you need to check everything as this certainly isn't normal. Good luck.
   / My ROPS is hitting My Fender! #3
The tranny/transaxle/gearboxes are all cast iron on an "L" series unit, so I doube they are bent. The ROPS and fenders are installed by the dealer as pare of the prep and something was probably installed incorrectly.
Sounds like a warranty repair to me (if there isn't a simple adjustment to make somewhere yourself.)
2004 KENWORTH BUCKET TRUCK (A50854)
2004 KENWORTH...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
Case 830 Tractor (A50514)
Case 830 Tractor...
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
