Just thought I'd share the portable Flux Core welder I just put together. It's a flux core wire welder meant to run on 2 car batteries in series. I tore apart my old Harbor Fart 90 amp welder that I haven't touched in years, modified the wire feeder a bit, and mounted it in an old DeWalt laser level case.
The idea is to have a compact, self-contained welder that can be used for emergency repairs anywhere I've got 2 car batteries available, such as off-roading or making repairs in remote locations.
It has a 300 amp car audio fuse inline just in case anything real bad happens. Normal welding should run about half that. I still have to add the battery cables. I'm going to take a pair of heavy jumper cables, cut it in half, use one half for the battery leads, and a piece of the leftover cable and the other 2 clamps for the single cable required to series the two batteries together.
I figured if ReadyWelder can do it with a spool gun, I can do it with a regular wire feeder.
