My poor Kubota L39 is not new anymore.
   / My poor Kubota L39 is not new anymore. #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
After +90 hours my L39 is starting to look kike a rental machine.
I am pushing it the same way I push my little B7200 Bota, and this makes me question my sanity, as I do rally care if I break this $40K with implements machine.
Within the first few hour of use of my new Borgford grapple I managed to bend a few of the upper rakes teeth. I am lucky I did not roll the tractor. I moved some very large Stumps and one rock in particular I lifted and am sure the weight was between 2,700 lbs and 3,500 lbs, a big near perfect cube of granite 23” x 40” x 48”. The L39 has been “up Armored” with reinforced front guard, Skid plates, Reinforced BH Bucket, Mechanical thumb, toolbox and chain box and with me and the grapple surely tips the scales at +7,800 lbs. With the backhoe extended the rear tires were barely on the ground or even floating as I very slowly transported this beast 400 ft the rock pile. Not good for the ront axle I know.
The Borgford grapple did not have enough clamp force to outright grab the slab shaped rock across the 40” width, but I stood it up and grabbed it across the 2-foot thickness then tried to curl it. The T1000 did not have enough to outright curl the weight, but to my surprise the loaded would lift. I dared not try to get I more than a few inch off the ground, but carrying was better than trying to roll a square block. I deployed the BH as a counterweight. I had the stabilizers down when I lifted the rock about 18” the ground to get the rock in position to drop.
Also, this size rock is about as large a rock as the BH can role out of a hole.
Needless to say this is pushing the L39.
I moved several ton plus other rock and stumps get the machine stuck maybe 3 times trying to back up the soft slope leading to the “Stump Cliff”
This is a stunt you could not get away with if not for the backhoe. Set engine speed at 1100 Rpm, 1St gear reverse and use the hoe to pick up and drag the machine to safety.
Or, if not stuck to bad, just pick the back of the machine up and swing it to more solid ground.
The BH is a real tool in getting a machine out of a bad situation. Here is an example of where not having a strong hoe can make a bad situation worse.
Last week I had to pull my truck & small trailer out of my wife’s friend farm which my stepson buried trying to get to the manure pile.
I was going to use their JD4300 to pull the truck out, but I nearly sank the JD trying to get close to the truck. It was read dicey getting the JD unstuck pushing it out with the bucket. I ended up calling the wife to come over with 100’ of cable and we yanked the truck out of the muck from a safe distance where the tractor was less likely to go down in the mud,
The L39 Survived this weekend a little muddier, the step-plate to the cab bent and some scratches to the loader tube. I am real lucky not to have a nice ding in the hood to stare at from rocks etc falling of root balls I was shaking out. I think I will discontinue that practice, as sooner or later the nice hood wont be so nice.
I will post pic’s of my set-up in action when I remember to bring a camera up the new property.
Maybe this grasshopper would have been better off buying a decent used full size construction Loader/back hoe or a clunker BH and a old dozer to beat up rather than tax a lightweight new still sort of shiny L-39.
I torture myself over if I had made the right choice. If I ended up with 20 tons of rusty iron that I could not resell, the reasonably trouble free and sturdy L39 will prove to be a good move.
If I could have bought used equipment, used it till I did not need it, and then bought a 50-80 Hp air conditioned cab Ag. type machine later, the L39 will prove to be an expensive compromise.
The Yanner, L48, JD-110 etc. would not do any better than the L39 as all are too powerful a toy for the backyard, but not really "earthmovers".
They fit the niche as Contractor do-all tools.
I guess I am have fun with the L39 in any case and it is a manureable machine for what it can do.
5th Wheel Dolly (A49461)
5th Wheel Dolly...
2015 INTERNATIONAL PROSTAR SLEEPER TRUCK (A50854)
2015 INTERNATIONAL...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
John Deere X740 Mower (A50514)
John Deere X740...
Unused 2025 CFG MH12RX Mini Excavator (A49461)
Unused 2025 CFG...
2001 FONTAINE CEMENT POD TRAILER (A50854)
2001 FONTAINE...
