BR,Thats encouraging for me anyways,,I was planning on putting over 1,000 lbs of the stuff in my little pond,,and its only about 20 by 20 feet,[probably less],,according to directions I read that would only be about 2 lbs per square ft,,,it says to use 1-3 lbs per square foot,,,worked into bottom,,,2 acres,,,,man,you'd need many,many tons of the stuff if you followed the directions from dept.'s of ag. from different states I read on internet,,,
Not saying that woulda totally fixed the leak or even slowed it,,but 1,000 lbs in two acres,thats not much of a test to my way of thinking,,,did you all even drain it? edit here,,,[actually I looked it up,,an acre is 43,560 sq ft,,two acres,than would be about 87,000 sq feet,,1 lb a sq foot,,over 43 tons!!!,,and at 16 dollars a hundred lbs,if you bought it by the bag,,,would be about 14,000 dollars!! holy #@$!!!,,did I do that right?,,anyways,,,1,000 lbs for two acres ain't enough,,but if it slowed leak,,than maybe 3-4,000 mighta really helped?? thingy
