Chipper My New Wallenstein BX42 Chipper
   / My New Wallenstein BX42 Chipper #1
dking
Bronze Member
New Brunswick, Canada
Kioti DK45SE / Massey Furguson 165
Picked up a BX42 for $2800 CAN. (That's about $2250 US) I can't belive how this thing just eats wood. I didn't bother with the hydrolic feed and I don't even see why you would need one - it pretty much pulled the wood right through. So far I give this chipper 2 thumbs up.
A video of the chipper in action. I chipped a 4" x 25' fir tree in just seconds. YouTube - Wallenstein BX42
   / My New Wallenstein BX42 Chipper #2
I bought my BX42 late last summer and used it for all my mullberry and oak thinning. Before that happened, I bolted two pressure treated 4x4s to the flat metal base plates. I have a thing about metal contacting dirt and creating rust. I'm also 6'-4" so by raising the chipper another 3-1/2" and still keeping the machine on the ground, it's a little easier on my back.
It works very nice behind my NH TC-40 and I didn't have to trim cut the PTO shaft.
   / My New Wallenstein BX42 Chipper #3
Ahhh, my BX24...what a pleasure to use. I love mine. Oak and cedar-vaporized. The PTO shaft has been a bit of a problem-too long for my JD4500. I didn't want to cut the shaft with a hacksaw as suggested by Wallenstein, so I had to be careful when lowering and raising it.
When I added a 3 pt quick hitch (the one from Harbour Freight-it was about $100) it now works perfectly and I can release it very easily. What a great tool.
Enjoy it!
BigfishTX
   / My New Wallenstein BX42 Chipper #4
Had my BX42 now for a year,probably has about 75 hours on it now,it has worked great for us. reversed the blades,installed new blades;that has been it. Love it.
   / My New Wallenstein BX42 Chipper #5
Oops, I meant I have a BX42, not 24...
BigfishTX
   / My New Wallenstein BX42 Chipper #6
I had mine out the other day, and I think I discovered one of the advantages of the hydraulic feed:
I got into a VERY hard 4" dead limb and managed to kill the engine (JD2520). Part of the reason for this is that, once it started "self-feeding" it was pulling the branch so hard, I couldn't control the input rate. Thus, it kept pulling in the branch while also lugging the engine, eventually stalling it.
I think, if I had the hydraulic feed, I would have been able to control the rate of feed and stop the branch before it killed the engine.
Overall though, I agree with the others, this thing is impressive. It's fun to toss a scrap 4x4 in there and watch it make mulch out of it in about 10 seconds!
   / My New Wallenstein BX42 Chipper #7
I agree, that is the biggest advantage to a controlled feed rate. It is very easy to stall a tractor with a self feeding chipper if what you are chipping is long and near the chipper and tractor PTO capacity. If you are running the chipper on a tractor with lots of PTO HP than it is less of an issue. That is one advantage to running a BX42 on a larger tractor instead of the larger BX62.
I have owned two BearCat chippers and I could stall both with long pieces of hard wood. They both had dedicated 20 HP Honda Vtwins on them and a large 140 lb flywheel. They both self feeded very well with sharp blades. If I ever purchase another chipper it will have hydraulic feed on it.
That's part of the reason I went for the 4" over the 6"... I knew that both my tractors had the power to handle the maximum size without trouble.
Wallenstein now has a 3" model that might be better suited to smaller tractors.
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
John Deere 2210 Compact Tractor (RUNS) (A50774)
John Deere 2210...
2022 Wacker Neuson SM100 Mini Skid Steer (A52748)
2022 Wacker Neuson...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
