My new tractor
   / My new tractor #1
check 6
South Texas
BX 2680. Front bucket, grapple, pallet forks, box blade aireator 008-5 excavator ZD 1211 mower RTV 500
As some of you have read, I decided to upgrade from a BX 25 to a B 2920 and I now have almost three hours on the new tractor. I am very happy with my decision. First, I was not really using the back hoe (except to do work for others) and second, I wanted more power for increase hydraulics capability. The B 2930 is every bit as maneuverable as the BX was and has more ground clearance. It is also shorter from the ground to the top of the ROPS so I am hitting fewer overhanging tree branches. I also like the three speed HST and now having to worry about the fragile transmission fan that the BX had and I had a BX expanded belly armor plate on mine. So far the only thing I would AND WILL change on the B2920 is the seat as it has the same poor seat as my BX has. I will go to the new seat that the BX 25 D has.
My new aerator/plugger from Everything Attachments works great on the "B" as does my Continental Belton 50 gal sprayer. I ordered it with the quick detachable FEL bucket and have a fork lift style attachment coming.
My mods so far are overhead work lights both front and back, a fiberglass canopy, my dash mounted cel phone mount and a switch panel to handle the lights and my 12 volt pigtail for the sprayer pump. I have also mounted eye bolts in the already drilled in the front chassis. Almost forgot I have re-enforced the top of the FEL bucket and mounted chain hooks and a receiver receptacle
Mods in the works are a back up camera (to many discs missing in my neck and spine), A NEW SEAT, fire extinguisher and a bracket to retain a hand rake. I may also come up with a container to hold a length of chain.
I will post pictures as I have time
   / My new tractor #2
Just got the BX25D so I am not sure I want to follow this thread.:confused3: I really wrestled with whether I would have the power I needed but I am on just an acre and half. Problem for me is the slope. Will follow and learn though. First time tractor owner so don't listen to me.
2006 Wabash National 28ft Dry Van Trailer (A51692)
2006 Wabash...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
