My new rubba blade!
   / My new rubba blade! #1
wetstuff
Salisbury, Maryland
J-D 1070, Furgeson F-40
Some nice gentleman donated a full recap within about 10 blocks of my shop on the bypass around Salisbury - Thanks! Before that, I had found a few crappy pieces.
Here's a company that sells nice, thick plastic which looks perfect, but was pretty expensive. IPX 2000 UHMW SHEET - Plastic Rods
Once I had this monster .. I had to figure out how to get it to flatten out because it was stiff as a frozen lobster tail. I started to notch it, but found weight, time and summer heat worked just fine.
I carried the whole mess to my local welder/fabricator, Welding by Jackson, Delmar DE. They were smart enough to center the mounting holes so I could flip it if wear becomes an issue. They also drilled the holes in the tread to match the holes in the blade and backing plate - that was lucky! All I had to do was buy a metal cutting blade for my Skill saw and nip the ends, then bolt it up.
I have some very industrial caster wheels to mount next .. may as well jazz up this old Meyers.
Jim
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
378663 (A51573)
378663 (A51573)
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
