My new CK2610
   / My new CK2610 #1
Teslaman
Newcastle, OK
Kioti CK2610
Hey all. After some time browsing this forum, I went with the CK2610. Seems like a good tractor so far. Love the fuel tank in the back instead of other brands in front. Bought from a well known dealer with lots of repair experience. It's been quit a digger with the FEL in Oklahoma clay.
   / My new CK2610 #2
Looks great. do you have a toothbar. look at a pirrahna it will make digging even easier,
   / My new CK2610 #3
Congratulations. It looks great.
   / My new CK2610
Thanks. Have seen some with tooth bar, but haven't needed one yet. Working on fish pond after house remodel done.
   / My new CK2610 #6
You should look into a tooth-bar for sure. You have to watch digging with fel, don't want to bend your bucket. That being said, we don't have clay here, it's mostly loam, hard pan and rocks, lots of them. I have a woods backhoe for around here in the Northeast. Enjoy your tractor, you'll be wondering why you waited so long to get one.
   / My new CK2610 #7
You'll find the beer holder works great with one of those Kioti can koozies.
   / My new CK2610 #8
I have the same machine I bought two years ago. Great compact. I have the older FEL that has less lifting capacity, but found the tooth bar didn't make much difference in digging, and when trying to smooth out a grade was just making it worse. I ended up getting the bucket lip Kioti makes for it to bolt on. I am very happy with that. I found the rear end is heavier than the Deere 850 I had so that helps even though both had fluid filled rears.
   / My new CK2610 #9
I agree, I have owned loader tractors since 1999. I have moved hundreds of yards of dirt without the aid of a tooth bar. I also found that I do not need as much rear ballast on the Kioti as I needed on the John Deeres.
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2014 Ford Transit Connect Van (A50323)
2014 Ford Transit...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
Year: 2015 Make: Crane Carrier Co. Model: Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Vehicle Type: Truck (A51692)
Year: 2015 Make...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
