My new Bolens 1060 G11XL Tractor
   / My new Bolens 1060 G11XL Tractor #1
Soccerpromaz
Just joined the site, I have a little over an acre in Canton CT and wanted a small tractor for my needs. I have had a Craftsman II Mower for the last 15 years but I wanted something with a small bucket on the front and maybe a rototiller on the back. I picked up this tractor for free and have been reading about running a power steering pump on the front pto to lift a small bucket. I dont really know much about the tractor yet but cant wait to learn. It has a newer 11hp engine from previous owner, he was going to build a drag racer. The rear axle leaks on the left side (seal is blown I assume). Any input on my project will be appreciated, here are some photos. I cant find much about this tractor and see very few photos online. I need information on the electric pto on front and wiring for it. The tractor runs but needs a new fuel hose, filter, and a battery.
-Mike
   / My new Bolens 1060 G11XL Tractor #2
Hi Mike , and welcome along with congrats on the Bolens , I myself just aquired one , but I had to pay for mine , lol. Check out sonnysbolensdotcom for parts , they seem to have alot of stuff for these bolens , good luck , and if yur gonna put hydraulics on it , try northerntool dot com , i put hyd on an older ford yt16 and used a small hyd pump that can run either clockwise or counterclockwise for easier mounting , have fun , Scott
Update
Fixed problem with fuel not getting to carb, raised the gas tank up a little. Threw a battery in it and drove it around the yard. Every gear except 4th works great, 4th works but it is hard to get into sometimes. Does anyone know where I can order rear seal for axle? I tested the front Pto and it works as well. Now that I know everything works I can start Beefing up my frame and preparing it for the loader.
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
