If you have the mower height adjustment knob (on the 2320) in lock position you won't have that trouble with the arms coming down. They are mechanically locked from coming down. You could also install the optional hydraulic lift which I did on mine and it was money well spent.Yseesee said:Looks like you are set to go. Very Nice!!
I noticed the arms under the tractor for hooking up a Mid Mount Mower (MMM). Be carefull when you lower your 3pt, the arms under the tractor tend to get hung up on things. I found out the hard way. I was mowing with a brush hog on the back and the MMM arms got all banged up! I actually had to replace the left one. I didn't notice they were dragging the ground until after a few were mowed and by then it was too late.![]()
I had the same issue with the arms in the back rubbing the tires. From what everyone is saying the I-Match or something similar is the way to go. I guess once you have the I-match setup you have to get some sort of bushing for everything you own??
