My MT160D Starter cranks clunky, not smoothly
   / My MT160D Starter cranks clunky, not smoothly #1
jer2000
:(The starter on my Mt160D doesn稚 crank smoothly as it used to. It cranks normally and then sounds like the starter skips with a little grinding noise and then cranks until it starts. It might skip/grind 3 or 4 times before it starts. Could it be the starter? Does this tractor have a starter Solenoid? Is there anyway I can test the starter or other starter components?
Once the tractor starts, she runs perfect.
Any help would be appreciated...
thanks
Jerry S in CA
   / My MT160D Starter cranks clunky, not smoothly #2
you would have to remove the starter and look at the gear that enguages the flywheel. through the hole that the starter was removed from look at the flywheel gear. you would have to turn it all around to see all the gear teeth.if these are all good the starter or the solenoid may be defective.check all the electrical connections.A & T Parts & Rebuilders try this site if you want to have it rebuilt.
1997 FREIGHTLINER WESTERN STAR DUMP TRUCK (A60430)
1997 FREIGHTLINER...
19010 (A55851)
19010 (A55851)
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
