My login keeps timing out within minutes
Status
Not open for further replies.
   / My login keeps timing out within minutes #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I haven't been posting here for quite a while, but I don't remember having this problem before. I was trying to make a new post and it was a fairly long paragraph, which took several minutes to complete. I don't type that slow, I was just thinking of what to say, then typing, etc. When I went to submit it, I was logged out and had to log back in again and start all over. It did it to me twice. I finally wrote up the paragraph in Word, then logged in again and cut and pasted the text into a new post. What is the time limit for making a new post?
   / My login keeps timing out within minutes #2
I'm having the same problem.
mark
   / My login keeps timing out within minutes #3
Danny, if there's a time limit before you get logged out, I sure didn't know it. I'm sometimes pretty slow, but I'm not having the problem you are.
   / My login keeps timing out within minutes #4
I have the same problem on two machines... work and home:mad:
   / My login keeps timing out within minutes #5
I found that while using IE, if I had active scripting turned off, that I would be logged off every few minutes. You might try turning active scripting on.
Cliff
   / My login keeps timing out within minutes #6
FIREFOX on both machines... not IE... I avoid IE for security and other problems unless I simply MUST use it.... which occurs because of the way some web sites are written.
   / My login keeps timing out within minutes #7
Please continue discussion in this thread. No sense having to post in two threads. BTW, I use Firefox, 1.5.0.7 and have no problems, so this is, most likely, a problem at the browser end, not at the server. Thread closed.
Status
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
Electric Concrete Mixer (A51573)
Electric Concrete...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
