My Kubota L4850 has L5450 stamped on it?
   / My Kubota L4850 has L5450 stamped on it? #1
ussofa
North Dakota
Kubota L4850DT
Right next to the hydraulic filter by the rear wheel on my L4850, their is raised lettering on the body of the tractor that says L5450. Is the main body of the tractor the same for both units? Is the only difference between them the size of the bore stroke?
   / My Kubota L4850 has L5450 stamped on it? #2
The L4850 and L5450 are almost the same tractor. Their R1 tires are different sizes (R4s are the same), engines also have different stroke. The L5450's LA1150 loader is a little stronger than the L4850's LA950 loader. The L5450 has more hydraulic flow, Cat I & II 3-pt hitch and there is extra steel around the front - tractor weighs about 300lb more. Take care, Dick B
   / My Kubota L4850 has L5450 stamped on it? #3
My L3400 fwd front Axle has "L3300" in raised letters.
2003 Ford F-250 Pickup Truck (A46684)
2003 Ford F-250...
2018 MITSUBISHI OUTLANDER SPORT (A48992)
2018 MITSUBISHI...
2016 MACK GU713 GRANITE TRI AXLE DUMP TRUCK (A45678)
2016 MACK GU713...
Lift Gate (A49251)
Lift Gate (A49251)
Amkus Rescue System (A46683)
Amkus Rescue...
Krause 1071 11-Shank 15ft. Disk-Chisel (A49339)
Krause 1071...
