My Kioti sc2210 has lost all hydraulic power after a change of the transmission filter (50 hrs. use)
   / My Kioti sc2210 has lost all hydraulic power after a change of the transmission filter (50 hrs. use) #1
Ortiz Ruiz
KIOTI/sc2210
Hi I am having problems with the tractor It has lost all hydraulic power...and apparently there is air on the lines that needs to be taken out (breeder system?) thru a valve? I don't know which valve or how to proceed? Any ideas, Comments? Suggestions. Please Advice
Ortiz Ruiz
San Juan PR
   / My Kioti sc2210 has lost all hydraulic power after a change of the transmission filter (50 hrs. use) #2
How much fluid did you loose when changing the filter and did you replace it? Hydraulics are self bleeding. Sounds to me like the fluid level is way too low.
   / My Kioti sc2210 has lost all hydraulic power after a change of the transmission filter (50 hrs. use) #3
As stated could be fluid level. If that's not it suspect a defective filter. Some tractors have a screen in the hydraulic system as well. That could be clogged.
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
9202 (A50322)
9202 (A50322)
