My John Deere L120 keep cutting off(go dead).
   / My John Deere L120 keep cutting off(go dead). #1
DJP
Jackson,MS
Mahindra,4500
I have a older L120 20-HP Brig. & Stratton every 15 to 20 minutes of cutting it shuts off go dead. I get off and pour gas down in the cooperator and it starts back up. Run again 15 to 20 minutes and it ***** off again. Do I need to change my fuel pump or the fuel filter???? Also why my cutting blades(The edge cutting system) stalls at times and pick back up with speed????? I put a bigger hole in the fuel tank cap, but it did not stop the cutting off.:mad:
   / My John Deere L120 keep cutting off(go dead). #2
I'd look at debris plugging up the fuel system, beginning at the fuel tank. Sounds like fuel starved. A nuisance for sure, but wouldn't change out the fuel pump right off the get-go. Track it down and know you have good flow through the fuel lines first.
Assume "cooperator" is the carburetor. ;)
   / My John Deere L120 keep cutting off(go dead). #3
Dj - have you looked under the fan shroud? Could be that you have a mouse nest in there that is causing the engine to overheat and thus causing it to stall.
Richard
   / My John Deere L120 keep cutting off(go dead). #4
Definitely check for fuel blockage. Look at replacing your in line fuel filter.
   / My John Deere L120 keep cutting off(go dead). #5
Check vent on fuel cap.
Stump Grapple (A49251)
New Holland 56B Hay Rake (A49251)
New Holland 56B...
2016 RAM LONGHORN 4WD CREW CAB (A45678)
2016 RAM LONGHORN...
2018 Chevrolet Traverse AWD SUV (A46684)
2018 Chevrolet...
Golf Cart (A48082)
Golf Cart (A48082)
2022 Ford Maverick Crew Cab Pickup Truck (A46684)
2022 Ford Maverick...
