My I think I need a tractor thread
   / My I think I need a tractor thread #1
laz
colorado
Kubota 3430D
Basically our house burned down in a forest fire. We are getting quotes
of 8k to remove the foundation (4-6 foot no slab, 1200 square feet). I figured
at that price I can do it my self and buy tractor to help. I am looking
for used BUT not a project, while my garage did survive, it has no power.
the land is 40 acres of mountain property everything from flat, to
"i'm not going to the south east corner ever again because i know how
hard it is to hike back".
So my price range is up to ~18k. My immediate needs are:
Front end loader to remove the foundation (i plan on renting a concrete saw
and cutting it into smaller pieces). and move logs.
4 wheel drive.
Back/box blade to cut access into burned areas to remove trees.
Chipper. Prefer 8 inch, prefer rotating exhaust chute so i can spread the
chips without a rake, automatic feed is mandatory (no gravity) prefer
an adjustable speed on the feed. I could possibly go down to a 6 inch
but i have had issues with 6 inch being undersized (towable from a
local rental company).
I can see a backhoe being very useful. Just don't know if i can afford it.
My long term abuse of said tractor would be maintaining the driveway
(grading snow, removal), chipping, hauling logs, pulling people out of the
ditch, anything to help with re-building, digging holes just because, or just
sell it after i am done.
Oh and i drive a stick so the transmission type shouldn't matter.
So my question is within those parameters what size and tractor should
i get and what chipper (i haven't been able to find a local chipper used so i
am assuming that will be new). If it makes a difference location is the
mountains out side of boulder colorado.
thanks
laz
Ps whats a CUT? i figured out some of the other acronyms but i can't get
that one
   / My I think I need a tractor thread #2
For starters, welcome to TBN and I am sorry for your loss.
Now onto the tractor issues.
For starters, if the 18k budget is for everything, figure on about 5k of that being eaten up with the chipper and box blade.
And BTW (by the way) CUT stands for Compact Utility Tractor.
If I were you, I'd recomend going to a dealer and looking at some new tractors. Not so much to buy, but to get a general Idea of what size tractor you are looking for. Some things to keep in mind that might limit the size you want are any tight areas on your property that you may need to get through, garage door height and space, trailering ability(weight and length) if that is an issue, etc.
Once you have narrowed it down a bit, post back with some of the model #'s you think are the size you want and we should be able to give you a lot better feedback.
But basically, ANY tractor from the small SCUT's (Sub-compact utility tractor) and up will do what you want. But obviouslly the bigger you go, the faster it will do the work and the larger log it will pull.
If you dont have any limitations on size for reasons mentioned above, get the biggest you can afford. And used tractors vary alot in price based on age, hours, and condition. If you dont mind buying a 8-10 year old tractor with ~2000hrs on the clock, then you should be able to get a pretty good sized tractor for your budget. Like a full sized "utility" tractor in the 40-50HP range. But if you are only looking gently used, like 2-3 years old and only a few hundred hours, you are going to be limited to something in the ~30 HP CUT range.
Do your homework and narrow it down a bit. You dont want to buy something you are going to be dissapointed with.
   / My I think I need a tractor thread #3
Good advice. I will only add 3 things:
When I started pricing tractors I was shocked to discover that they retain their value much better than most things. There is very little depreciation with age - it's more a matter of hours of use and condition.
Determine what size implements you will need to do all the jobs you want done and then buy a tractor that can handle those implements.
Have an eye toward stability. Wheel track width and center of gravity become very important issues the minute you start working in the woods or on a slope of any magnitude.
   / My I think I need a tractor thread #4
Wow, that has to be terrible to lose your house. I kind of question the need for a big self feeding chipper. They are very expensive. With 40 acres can't you push into piles and wait for burn season? I've gotten where I don't even bother to burn anymore. Just push into pile in the wood line for wildlife habitat and the piles go away naturally in 3 or 4 years.
Good luck,
MarkV
   / My I think I need a tractor thread #5
Can't really improve on the advice. You might want to add a little more to your profile for members to understand your situation.
Like MarkV, I don't chip anything, too much work. I pile it up and burn it or use it for wildlife cover.
I personally would like about a 50 HP of which there are a bunch out there. If you are completely new to tractors, rent one a couple of times to get a little seat time and yardstick to measure needs and performance parameters.
Good luck.
   / My I think I need a tractor thread #6
your going tobe doing alot of loader work.so that tells me you need atlest a 40hp 4x4 tractor.you should be able to get that for $18,000 or less depending on what you get with it.
My original question is open-ended because i didn't want to limit any
answers to mistaken research on my part. So within my assumptions
and available locally i have narrowed my search to a kubota L3400 and
L2800 both with loader and backblade both about 14k and under 150 hours,
the 2800 has HST, the 3400 has gears. i figured at least 25 horse power
at the pto should be enough to run a chipper
As for the chipper i have ruled out liberty altho the girl is very nice. I am
looking at the http://www.Woodmaxx.com/ possibly the jinma but i don't
like the fixed chute and 6 inch size.
laz
Good luck,
MarkV
Reasons for a chipper:
the original fire was started by a slash burn.
the chips hold the hill together from water erosion.
slash doesn't go away in colorado it just grows bigger.
i am going to be using whole trees to make wildlife habitats
laz
Here is my situation it has been cleaned up since then and either i am used
to it is starting to recover (less then a year). The first 3 pictures are of our
friends houses. Turn down the volume if you don't want music in the slide
show.
http://www.cybox.com/~laz/fire/fireslideshow.mp4
The first slide show is from when we sneaked in.
the second one we where legal and had more time so the more photos.
it has some better pictures of the slope that i WILL not go on with a tractor.
Yes the garage survived no the tractor doesn't get the garage, the motorcycles
get the garage and the garage has no real power (4000 watt generator can't
run the compressor i tried) so no real repairs. hand tool repairs are possible.
http://www.cybox.com/~laz/fire/firstview.mp4
laz
   / My I think I need a tractor thread #10
...possibly the jinma but i don't
laz
I clicked on that Woodmaxx link. They don't list (or I missed it) PTO HP requirements.
Undoubtedly chinese due to the price.
As far as PTO requirements, 25 PTO HP runs a Woods 5000 with a 5" capacity. I think you'd want 35-40 PTO HP to chip 8" material.
43030 (A51691)
43030 (A51691)
1838 (A51248)
1838 (A51248)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
