Loader my first skid steer..... information wanted please....
   / my first skid steer..... information wanted please.... #1
junkmonkey
Milton, Kansas
case 1537
I have a Case 1537 skid steer that leaks oil from behind the right front tire. Pulled tire and bearings? and seal? are loose and leaking. Where do I start? I would appreciate whatever help anyone could offer on the best way to start this repair. thanks in advance.
   / my first skid steer..... information wanted please.... #2
seals only go bad for a few reasons.
1. A bad vent causing excess pressure.
2. Worn shafts or bearings.
3. Something entering and injuring the seal.
Is it on a drive motor?
I have not had a chance to tear into it yet. knowing absolutely nothing about skid steers, I have been a little anxious about tearing into it until I know a bit more. The shaft/hub that the wheel bolts to is wobbly and oil is leaking onto the inside of the tire. it is a belt drive setup so I don't know what that entails as far as drive motors are concerned.
   / my first skid steer..... information wanted please.... #4
Don't be afraid. It's no different than a car or truck or tractor. It's only as afraid of you as you are it lol
   / my first skid steer..... information wanted please.... #6
I have worked on 1845 case skidloaders and there pretty simple they have a nut,sprocket,and bearing on inside chain case on that side there were acess covers in the cab to get to the nut and sprocket the bearings face eachouther
2015 GALYEAN 180 BBL STEEL VACUUM TRAILER (A52472)
2015 GALYEAN 180...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
