My cub cadet LTX 1040 will crank over but not run
   / My cub cadet LTX 1040 will crank over but not run #1
sarge97
Elkton, MD
2011 Cub Cadet LTX 1040, 1960's Allis Chamers D-17 Diesel
I need help, my cub cadet LTX 1040 will crank but will not run. I was backing up, and my son left a rake in the yard, the mower rolled up the rake and came down hard and the mower just shut off. I tried starting it, the engine would crank but not run. The mower is 3 year old with just over a 100 hours on it. I've looked underneath and can't find any wires that are loose or anything disconnected. The only thing I see that may be a problem is the linkage arm from the forward - neutral - reverse lever going to the transmission area, seems to be alittle bent, it's hard to shift it into forward now. Any help would be appreciated, thank you.
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
