My choices
   / My choices #1
passgas55
Bronze Member
After been thinking about a tractor for a year I finnally have the money or close to it for a yanmar. My spec is to be a powershift and have a water pump. The tractors that are in the running are 1610, 1610D or a 2210.
The 1610 series I want a 42" rotary cutter while on the 2210 I would want a 4' rotary cutter. I will be cuttting 2.5 acres of pasture with some light clearing in 3 acres of woods. I am leaning towards the 1610 size because I did do a drive way, house pad and did plant some trees. I like the 2210 becasuse of the power/weight for working the woods. Grass cutting will be my main function and if a house is built more stuff will end up in the 2.5 acres part. How far apart the prices will determine which tractor I will get but I think the 2 wheel drive 1610 will be my choice.
   / My choices #2
If you are sure thats the one you want, Go for it! But out of the choices you mentioned, I personally would go with the 2210 unless you are planning on adding a loader later on down the road.
Travis R
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
