My BX2320 keeps on going.. and going
   / My BX2320 keeps on going.. and going #1
true grit
Poca, WV
Kubota 2230 Compact Tractor
After i finished mowing the other day, my Kubota BX2320 would not shut off. I thought the ignition was the guilty party because the key would not go into the off position. I replaced the ignition and it wasn't the culprit. The kill switch under the seat is not working as well. What should I be looking for?
thanks
Ron
   / My BX2320 keeps on going.. and going #2
Check the 10 amp timer fuse....I've had this problem.
   / My BX2320 keeps on going.. and going #3
Sounds like your issue is the fuel shut off solenoid. Uses a 12 volt current to shut the fuel to the engine off once you turn the key to the off position. Could be defective or maybe a blown fuse. Diesel engines don't require an electric current to run, so the only way to shut them off is to cut the fuel delivery off.
Thanks I checked the fuse first. (Cheapest and quickest fix). But it was indeed the solenoid. She is back up and running fine.
1274 (A50490)
1274 (A50490)
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
UNUSED HURRICANE 40' CONTAINER (A51248)
UNUSED HURRICANE...
