My B8200 is emptying the hydraulic fluid out, the engine breather and dip stick
   / My B8200 is emptying the hydraulic fluid out, the engine breather and dip stick #1
Adamde
Newbury
Kubota B8200
Hi
My B8200 is emptying the hydraulic fluid out the top engine breather and the dip stick hole
I hope some one can help?
I have replaced the hydraulic pump seal, what else could it be??
   / My B8200 is emptying the hydraulic fluid out, the engine breather and dip stick #2
You probably have a hyd pump seal leak filing the crankcase.
Did you inspect the pump shaft for a groove? If the shaft has a wear groove, no seal is going to help.
Next option is to take it to a hyd shop for testing and new seal and or shaft.
Any time your crankcase level is above the mark, it could be water, diesel, or hyd fluid.
   / My B8200 is emptying the hydraulic fluid out, the engine breather and dip stick #3
I also replied to your post on OTT
Have a experienced shop replace the seal again. They know what to look for in case there is some other issue, as you stated your not that mechanically inclined so you should stick to the small stuff.
I've not been using the tractor just running it for 1-2 mins max to see if the new seal fixed the problem.
It started fine first time a little white smoke that cleared. Engine sounded ok.
I will remove the hydro pump and make sure the seal is still in position.
hydro oil wise is HM32 ok to use?
Could there be a blockage that is casing the seal to blow?
Would a new hydro pump solve the problem?
Cheers
   / My B8200 is emptying the hydraulic fluid out, the engine breather and dip stick #5
Why jump the gun at doing any more until you run it long enough to find out if you fixed it.?
   / My B8200 is emptying the hydraulic fluid out, the engine breather and dip stick #6
Just bring the hyd fluid to level and the crankcase fluid to normal and then run for about 15 min.
Then stop and check levels again.
1831 (A51247)
1831 (A51247)
2003 ford f750 (A55788)
2003 ford f750...
Hose Reel (A55758)
Hose Reel (A55758)
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
49" X 58" TRAILER TAILGATE (A54756)
49" X 58" TRAILER...
