My 4wd 4025
   / My 4wd 4025 #1
MutzFarm
Texas
Kubota M62
Havent been on here in a while and just wanted to share a picture.
My 4wd 4025 with a 8ft hay king disc loaded with a 55 gallon drum of water. 20160226_085847.jpg
   / My 4wd 4025 #2
How has the 4025 been for you?
   / My 4wd 4025
It is an excellent machine. Simple. Has enough power to get done what I need to. I always run out of traction before I do power. It can use 6ft pto driven equipment, pull implements 6ft and bigger, and double stack round bales. If I would do anything different I would buy two units. A smaller one than this and a bigger one. With that said I believe this to be the perfect all around unit.
   / My 4wd 4025 #4
I'm glad you like it. Do you ever double clutch and shift on the fly? I've gotten decent at it in the higher gears. no reason to do it in the lower gears - easy enough to stop.
   / My 4wd 4025
Its rare Im in high range. When I do so I just put it in that gear and go.
   / My 4wd 4025 #6
Lots of low end in that tractor... great machine probably my favorite model of theirs.
   / My 4wd 4025 #7
I have the same tractor (two years now), it's simple just the way I am-
The weather is good enough now that I should get out there and replace some fence. Drilling holes in the dirt is fun, the rest not-so-much!
   / My 4wd 4025
I guess if I had a real complaint it would be there is no screen in front of the radiator. You got the one in the grill, but you will have to blow out the radiator when the unit starts to get warm instead of pull out a screen and tap it on the tire or something and go again.
   / My 4wd 4025 #9
It would slow down the process for sure but when dust gets bad enough the screen don't help much. Keep a paint brush with you and you can brush off the front if it gets matted up.
   / My 4wd 4025
Some how manages to get past the grill in the screen and on front of radiator. I carry an air tank in my pick up and blow it out from the back of radiator toward front of tractor.
Working on installing a 12 volt air compressor system on my pick up just for this reason.
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
