My 425 fan failed!!
   / My 425 fan failed!! #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
I noticed yesterday after cutting the grass that the cooling fan on my 425 was not running.
I checked the fuse and it was blown. I replaced it and mowed some more but even though the temp was hot enough, the fan still did not run.
I checked the fuse again and it was ok this time.
I checked the temp sensor contacts and they were closed when the oil is hot and open when it cools off.
I took the fan off to see if anything was not right and it all looks ok. The fan spins freely too!
Any other suggestions?
   / My 425 fan failed!! #2
you gettting voltage to the fan? or you could check resistance across fan or even run power to it directly to see if it spins.
   / My 425 fan failed!! #4
If the motor is bad it couldn't be much different from the set up used on radiators of automobiles. Might be one could match one from a junk yard? Motor, fan, guard and all.
</font><font color="blue" class="small">( I agree. Run power to the fan directly and see if it spins. )</font>
Moss: I think I read that you have done this with some wire and allegator clips in the past. Where did you connect them?
Battery positive to ?
Negative to chassis?
   / My 425 fan failed!! #6
Pequeajim,
Maybe take a look at this thread {HERE} from few months ago. Also, FOURTEEN has recommended a number of times jumping the fan circuit such that the oil cooling fan remains ON all the time.
Let us know what you find.
   / My 425 fan failed!! #7
Not me. Mine's always worked. /forums/images/graemlins/crazy.gif
I'm guessing just take a couple of wire leads and clip them from the battery directly to the fan leads just to see if it spins. If it does, look for the problem elsewhere. If not, the fan motor is probably bad.
I was looking for the fan leads (bare point of contact), last night. I even took the fan off but the leads on the fan side are sealed, (understandably). I can see the one lead coming off of the temp. switch which I am assuming is the hot wire?
I suppose that I could read voltage by touching the hot side of the switch and chassis.
It was getting dark and I could not see where the other one ended up. I will look again tonight.
   / My 425 fan failed!! #9
Don't feel like the lone ranger, i am on my third one and a second thermostate including one melted battery top.
I will let you know where i found a less expensive fan, which lasted at least one year. The pt fan did not make it a whole season! Around 650 hours.
   / My 425 fan failed!! #10
Automobile radiator fans work good for my 1445. They come in all sizes and around $10 to $20 bucks.
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
John Deere 6120E (A50323)
John Deere 6120E...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
