My 4110 CUT moves a house
   / My 4110 CUT moves a house #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
Here's my 4110 moving a house. Mighty impressive, no?
Cliff
   / My 4110 CUT moves a house #2
That's cute, Cliff! /forums/images/graemlins/cool.gif
You should have taken it one step further and had the rear tires raised a little off of the ground! /forums/images/graemlins/shocked.gif
   / My 4110 CUT moves a house #3
It wasn't a house, but my tractor did something similar last week...
48" box and pan brake in the crate...400 lbs or so...piece of cake /forums/images/graemlins/smile.gif
   / My 4110 CUT moves a house #4
I think you guys might be getting too close to the diesel fumes.... /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( It wasn't a house, but my tractor did something similar last week...
48" box and pan brake in the crate...400 lbs or so...piece of cake /forums/images/graemlins/smile.gif )</font>
OK, you can say it's a "pan brake", but I'm wondering whose body is in that pine box?
Cliff
</font><font color="blue" class="small">( I think you guys might be getting too close to the diesel fumes.... /forums/images/graemlins/grin.gif )</font>
Well, you know, someone on TBN was talking about Biodiesel smelling pretty good, so I tried some and sat their sniffing it for while, just so I could be sure. You know, it does smell better (especially with a dash of vanilla). It also doesn't leave you with that diesel hangover you get when you sniff regular diesel. Not that I've ever sniffed regular diesel.
Cliff
   / My 4110 CUT moves a house #7
Henro,
Are them chains on for a reason or are you using them for ballast?? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / My 4110 CUT moves a house #8
Murf,
Funning thing is my first thought was, those chains are holding the crate up! /forums/images/graemlins/grin.gif
Then I remembered with all the rain this year, after taking my chains off early spring, I put them back on a couple weeks later as I was having traction problems with the wet conditions.
Then a couple days ago I realized that in addition to aiding tractor, they are pretty heavy and add close to 80 lbs per tire, and are effectively wheel weights of sorts, contributing to stability. The loaded tires+chains seemed to be enough rear ballast for the crate, as it was mostly air, except for the 400 lbs of metal... /forums/images/graemlins/smile.gif
Cliff, I got rid of that box pronto...I was afraid it might be my body that would be in it if the wife realized how much money I have been spending on myself recently... all tractor and tool related purchases... /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
   / My 4110 CUT moves a house #9
Continuing the proof that we move a lot of things other than dirt with our loaders, here's a photo of me moving a rolltop desk. I just let it hang below the forks and all I had to do was get it through the door while trying to avoid the deck column. Everything came together without a scratch. Of course the desk probably weighs only 150 lb or so. /forums/images/graemlins/grin.gif
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
6 Pallets of Oil / Chemicals Absorbing Pads (A53117)
6 Pallets of Oil /...
Econoline RA-48X24 Sand Blaster (A53117)
Econoline RA-48X24...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2013 John Deere 650K LGP (A47477)
2013 John Deere...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
