My 3215 FWD update:
   / My 3215 FWD update: #1
bill6
Kennewick, WA
....Just checkin' in to say hello. Thanks to rback33 for contacting me to see how things are going.
The 3215 is now slighty over a year old. I have about 185 hrs on it. The only "issue" has been the hour meter. The first one quit at 66 hrs. So the dealer mailed me a whole new instrument panel. I installed the new panel, and the hour meter quit again at 35 hours. Now the dealer sent me another new panel, and I recently installed it. The meter is driven by a rotating cable, similar to a tachometer cable. We'll see how long this 3rd one lasts. Fortunately, I can replace the instrument panel in about 1 hour.
The tractor is still extrememly clean. But it's been frustrating for me, because I spend aprox an hour cleaning it, for every hour of operation. Maybe something's wrong with me. For example, after using the tractor for a 2 hour job, I absolutely cannot put it away in the garage and sleep well at night, without first spending 2 hours: washing it down with a garden hose thoroughly, drying it off with a chamois, wiping any remaining dirt from hard to reach places with a rag, using my car-show polish to bring all exterior painted surfaces to a high-lustre again, applying Armor-all to the tires and all rubber seals, then finally lying down under the machine to wipe all dirt and grease from the bottom side.
The ML 111 loader has worked perfectly, can lift 1450 lbs to full height, and is extremely stout and durable. Every 5 hours I grease all 12 loader zerks with Red Line synthetic grease (very high quality)
The Mitsubishi turbocharged diesel continues to amaze me, with it's power and fuel efficiency. It ALWAYS starts immediately, runs perfectly smooth, and seems solid as a rock. Near max RPM (2575) it will burn about 1.2 gallons per hour. But after engine break-in, I have normally run 1750-1850 rpm, if not under heavy load. It only burns 0.65 GPH with this RPM setting; very efficient.
Generally I haul gravel from a large pile, break up plots of ground with a box blade & scarifiers, smooth & level dirt with my 84" landscape rake, load rocks & boulders into pickup trucks, and operate the 5' bushhog to knock down thick grass and wheat stubble.
Recently I purchased a 72' Howse finish mower, brand new from the Howse factory in Mississippi. I chose this model (C372) after MANY hours of research and reading. It has by far the highest (tallest) gear ratio of any comparable FM, allowing me to maintain a very high blade tip speed, at relatively low engine RPM, thus saving fuel. Also it has pnuematic tires, heavy 7-gauge steel deck, rear discharge, and powder coated paint. The key is to mow OFTEN. This way, the grass is never very tall, there's not alot of blown clippings, and you can mow at a faster ground speed. I found a brand new product from Firestone: turf tires that will fit my OEM Mahindra wheels; therefore I can change between turf and industrial tires!
Very frequently while operating, I bring the tractor back to the garage and open the hood and use compressed air to blow the dust off the whole machine. I remove and blow out the air filter.
Over all I am very pleased with the 3215. Sure, it needs a larger fuel tank, retractable seat belt, a cupholder, a toolbox, high-mount lights, a rear remote or two, etc, but still I like it very much. I love driving it, using the loader, working the land. But perhaps I'm not "wired" properly as a tractor owner. Mentally, I project the image of my highly polished Honda Insight that I display at car shows; as well as my clean & shiny airplane......and expect my Mahindra to look the same. Sometimes I even hesitate to use the tractor - - - because I might get it dirty!...........
   / My 3215 FWD update: #2
Bill,
Couple questions. Is your 3215 a gear model? I ask because I have a 2615 HST and generally need to keep my RPMs above 2200. Could be the nature of the beast? Also, could you share a link, model number, or name of those Firestone's? That just might come in handy some day.
Thanks for sharing,
Matt
   / My 3215 FWD update: #3
bill6 said:
..., after using the tractor for a 2 hour job, I absolutely cannot put it away in the garage and sleep well at night, without first spending 2 hours: washing it down with a garden hose thoroughly, drying it off with a chamois, wiping any remaining dirt from hard to reach places with a rag, using my car-show polish to bring all exterior painted surfaces to a high-lustre again, applying Armor-all to the tires and all rubber seals, then finally lying down under the machine to wipe all dirt and grease from the bottom side.
Amazing, that's what I do to my girlfriend.
Hi Matt; Yes, 3215 FWD means it is a GEAR model. On mine, running the lower RPM's, under small to moderate load, works fantastic and saves fuel. If I'm pulling a heavy disk harrow in soft ground, then I need the horsepower and throttle to 2350 to 2550 or so. But for general, easy cruising I run about 1800.
For the front tires, I have Firestone turf 27 - 8.50 X 15. The rear was the new product. It's a metric size, and is a direct replacement for the OEM. It is Firestone 380/70 D 19.5 This week I have my industrial's mounted, but next week will get back to some serious mowing, and will put on the turf's.
For cost, I think I paid $90 each for the turf front tires, and $285 each for the rears.....
   / My 3215 FWD update: #5
HangtownMatt said:
Bill,
When you say generally keep the rpms above 2200, is this under load or just maneuvering around? I also have a 2615hst and rarely need to take my rpms above 1800-1900 unless I'm running a 540 implement. Even in high gear, my motor is more than happy at 1800 unless there are hills involved.
Also, I too am interested in the turfs...
   / My 3215 FWD update: #6
Could I suggest you invest in a power washer... rather than a garden hose.... and just let the sucker drip dry... and try to curb your other clean-up impulses:D
Its a TRACTOR... and it goes out where things are gritty and grimy... it's NOT a showroom instrument... it's natural patina is properly obtained thru use and sun fading.... that's what makes it look good.... try to gain an appreciation for good, honest dirt and dings... it'll make you feel better... takes less time, too:eek:
   / My 3215 FWD update: #7
I have to agree with texasjohn, get a power washer. It will cut your cleanup time by more than half.;)
   / My 3215 FWD update: #8
bill6 said:
The tractor is still extrememly clean. But it's been frustrating for me, because I spend aprox an hour cleaning it, for every hour of operation. Maybe something's wrong with me. For example, after using the tractor for a 2 hour job, I absolutely cannot put it away in the garage and sleep well at night, without first spending 2 hours: washing it down with a garden hose thoroughly, drying it off with a chamois, wiping any remaining dirt from hard to reach places with a rag, using my car-show polish to bring all exterior painted surfaces to a high-lustre again, applying Armor-all to the tires and all rubber seals, then finally lying down under the machine to wipe all dirt and grease from the bottom side.... {snip!} ...I love driving it, using the loader, working the land. But perhaps I'm not "wired" properly as a tractor owner. Mentally, I project the image of my highly polished Honda Insight that I display at car shows; as well as my clean & shiny airplane......and expect my Mahindra to look the same. Sometimes I even hesitate to use the tractor - - - because I might get it dirty!
Good to hear from you again Bill... and glad to hear that you are continuing to set the standard on keeping a truly "clean machine"!!! Please don't get discouraged or bail out on your principles! Do like TexasJohn and MtnViewRanch are saying and get yourself a pressure washer! I would only add that you can use the Harley owner's trick of using a clean/dedicated, high-velocity leaf blower as a sort of Beast blow dryer after the pressure wash. It is also great as a "pre-wash" loose sand/dirt remover to avoid making mud puddles on your fine machine. While not as good as a full towel or chamois drying, it can be quite acceptable with a little after-the-fact touch-up. I also use WD-40 extensively in lieu of wax or Armor-all. Not sure if this could be harmful if left in the sun too long, but it sure works great and fast on my normally garaged machine.
My other trick is that I bought an insanely expensive can of paint from the local paint specialty company matched 100.000% exactly to the color and texture of the gray underbelly of the Red Beast. I use it frequently to touch-up wear points and control minor rust stains. It is the icing on the cake of keeping your machine looking like brand new!
My only cosmetic/clean-up regret? I'm having a horrible time dealing with all the ink black grease smears and droppings caused by my choice of a particularly nasty lithium multi-purpose grease I bought from TSC. It is the messiest grease on the face of this earth. I have GOT to find something that cleans up a little easier. :rolleyes:
Dougster
   / My 3215 FWD update: #9
Some people have WAY TOO MUCH time on their hands. Maybe you should change the oil every 10 hours also.
   / My 3215 FWD update: #10
QUOTE]
I keep the RPMS up around 2200 even when I'm simply moving around. And the reason for this is I don't like the sound I hear comming from the hydraulic system. It sounds to me like it's straining. I'm not sure, but it seems that increasing the RPMs either drowns this straining noise out with more engine noise, or it pumps fluid faster which increases the volume and removes the strain. I don't know, but I would be interested in knowing more about this.
Matt
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2015 Toro Z Master Professional 64in Zero Turn Mower (A50322)
2015 Toro Z Master...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
