My 3130 will not start - Display flashes HST NEUTRAL
   / My 3130 will not start - Display flashes HST NEUTRAL #1
brirob62
I have 2003 Kubota Grand L 3130 that I've NEVER any any problems with since buying it new from my dealer. Now it will not start. It displays "HST NEUTRAL" so apparently it thinks the pedel has not returned to the center/neutral position. Pedel seems fine. Linkages seem fine. I found the switch on the opposite side of tractor that apparenly senses the position and manually pushed it to see if that made any difference and it does not. (didn't put a tester on the switch yet - that's next but not exactly sure which of the 4 leads are supposed to be switch leads...)
Any other ideas? Is this a common problem with a common cause?
Oh- the other thing I tried is hot-wiring a hot lead to the solinoid switch wire. engine turns but will not start.
Thanks so much! hope someone can give me some ideas.
Brian
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2014 Peterbilt 337 Forestry Grapple Truck (A50323)
2014 Peterbilt 337...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
