dcbx1 said:
I have had my 1850 for about 4 months and have had no problems since the first week bugs were worked out.. It mows my lawn in half the time as my old toro, and uses far less fuel.. I have had the recall for the seat and my hour meter did stop working, these are being fixed as I write this . I do have a couple of ?'s to ask those of you with more experience than myself... 1. Should I do my own 50 hr service? 2. Should I use Super UDT, I live in NH and it gets cold in Winter. 3. Does the mower deck come off easily? 4. Has anyone had experience with snow removal with the FEL? 5. I am thinking of getting an extra set of mower blades, does anyone use Gator Blades on there Kubota mower decks.......... than ks for your help
I have a little over 200 hrs on my
bx1500. If you consider that close enough, here are my responses.
1. If you have the time (2 - 4 hrs), basic tools, basic skills, and are so inclined, I see no reason not to do the 50 hr service yourself. It's a good way to get really familiar with your machine.
2. I would recommend Super UDT, if you can get it. For some reason, it seems many dealers have no interest in selling it.
3. It takes a little practice, but after a few times, removing and installing the deck becomes a fairly simple procedure that can be performed in a few minutes. I think removing and installing the pto shaft is the most awkward step. Just make sure the collar locks when you install on the pto. Give it a few good pulls.
4. I was pleasantly surprised with how well the FEL works for snow removal. I would definitely try it before buying a separate blade or blower attachment.
5. Can't help with that. I will say though, that clippings seem especially prone to sticking to the deck. I have to scrape the deck nearly everytime I mow.
