MXM 120 Hydraulic Valve, Joystick control
   / MXM 120 Hydraulic Valve, Joystick control #1
mbmrang
Dixon, MO
Farmall 55
I've done some searching and have come up short so far but I am in need of the port diagram for the valve on a MXM 120 Case. It has the joystick control in the cab.
Long story short, we installed a woods loader and mount kit on the tractor this weekend and the hose kit had the hoses going to the rear remotes for the loader. We have hooked them up to use in the short term but we need to get the correct length hoses yet to connect to the valve that is located under the cab. So I was hoping to find which ports did what so we didn't have the trial and error method to get the hoses connected correctly. It appears that the bottom 2 would run one set of cylinders and the top would run the others, but I could be wrong in my assesment of that as well.
Any help would be appreciated. Thanks
Mike
   / MXM 120 Hydraulic Valve, Joystick control #2
Do you have any pictures of the valve? All sides.
We might be able to figure it out.
I can get a few pictures tomorrow but it will be hard to get good ones. It is mounted under the cab. 2 ports are visible along with what I think are pressure settings dials. I think the other 2 ports are on the bottom but I cannot get a view of the underside. I will see if I can come up with the correct part on case's parts page to help out. I've looked there but they only show the part pic in a general view with no hoses connected.
I have the pics but will have to wait til I get home to my computer to upload them. But it is a Husco 5005c. Which appears to have 2 ports out the bottom. I'll have to figure out if that's just an extra place to send out on the front of the unit. They are a vertical section valve.
After wiping around and getting a good angle, I found a couple of numbers and was able to figure out the part number. After searching I found the spec sheets and figured out how to hook up the loader. I haven't hooked it up yet since I need get a couple of fittings to make it work.
Thanks though
PAIR OF 5' CLIP ON TRAILER RAMPS (A54756)
PAIR OF 5' CLIP ON...
Unused Delta Crash...
BUNDLE OF 25" - 49", 2" X 2" TUBING (A54756)
BUNDLE OF 25" -...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
Krause Dominator 4850-18ft (A55301)
Krause Dominator...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
