MX6 in a 4310
   / MX6 in a 4310 #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Deere doesn't rate the 4310 for a MX6
I got to try one today. The cutter is fantastic. We are VERY hilly, and there were no problems handling it. The cut was great. The cutter is MUCH noisier than the LX, but then, it has chains, which seem to be the cause.
The only problem seems to be that it severely lugged the engine on startup. After that it ran just fine. We got better at starting it, as the day went on.
My wife did hit a 6" long piece of 2" schedule 40 pipe. Big Bank. The pipe got cut, but not a mark on the cutter. Fortunately, no one was hurt...
   / MX6 in a 4310 #2
That's pretty cool. I didn't think the 4310 would be able to handle it. Does it make the front end pretty light, even with the loader? Another thing that I am wondering. If something should go wrong, would it affect the warranty at all?
   / MX6 in a 4310 #3
Sorry for the dumb question Mike,but what is exactly a MX6. I think I could make a guess, but not sure????. Thanks
   / MX6 in a 4310 #4
</font><font color="blue" class="small">( what is exactly a MX6 )</font>
It's John Deere's medium duty rotary cutter with a 6' cut, look here for more info.
The last I knew, there were no stupid questions /forums/images/graemlins/grin.gif
Waldo
   / MX6 in a 4310 #5
Sound like you need a new pic under your name (hint,hint...)
   / MX6 in a 4310
<font color="green"> Does it make the front end pretty light, even with the loader? Another thing that I am wondering. If something should go wrong, would it affect the warranty at all? </font>
With the 430 loader, standard bucket and loaded front tires, there is NO handling issues. I have worked that pretty hard, no babying it. I didn't want to be extra soft and agree to buy it THEN find it made things tippy. So I have raced up and down hill with it raised for transport. I have pulled out from a standstill will full juice at all ranges. I haven;t tried without the loader, I know it will be light up front, but am pretty sure it'll be manageable.
As to warranty, it was my dealer that thought I should be using it, he assures me there are no issues. I will talk to him about it lugging the engine, just to make sure...
   / MX6 in a 4310 #7
what type of stuff are you cutting with it?brush grass etc.
   / MX6 in a 4310
Am I reading this correctly? it looks like I oughtta be at 2000 rpm when starting the pto for maximum torque and Hp. then move up to 2600 (for pto speed...)
thanks to jmIII who oeiginally posted this graph...
   / MX6 in a 4310
<font color="orange"> what type of stuff are you cutting with it?brush grass etc. </font>
Very light brush and heavy grass. I am maintaining my pasture....
   / MX6 in a 4310 #10
Looks like your reading the charts correctly, however - unless you have a slip clutch on that cutter, engaging your PTO, at that high RPM, will almost surely, take out your shear pin.
I have a 4310 and bought a new/discontinued JD 513 cutter. This is JD 5' medium duty cutter that has been replaced by the newer model.
It does not have a slip clutch on the cutter, just a shear bolt. Even at idle, when I engage the electric PTO, the very sudden and abrupt torque on the cutter, causes the swivel blades to snap out, and about 1 out of every 3 times, takes out the shear bolt. I would sure be careful about engaging the PTO on one of these 4310s at any speed above idle. Even if your cutter has a slip clutch, the violent change from nuetral to 3/4 RPM on the gears, shaft, clutch, etc., is going to cause a lot of premature wear/tear on your equipment.
I would only engage PTO at idle, then encrease RPMs to obtain the best cut for the situation.
On my rig, without the 420 loader on, with the 513 deck raised up off the ground, the front end gets real light. No loaded tires or front weights. Hit a dip at speed, and you would be pullin a wheelie. With the deck down, and tail wheel on the ground, it works fine even on very steep hills.
Have fun,
DT
PS: Sorry I never replied to your e-mail, had to have surgery on left leg, been out of it for a couple of weeks. Still have same oversize tires on tractor, can't even drive it right now.
See ya.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
LandPride RCF2072 (A50120)
LandPride RCF2072...
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
Bobcat T190 Skidlaoder (RIDE AND DRIVE) (A50774)
Bobcat T190...
Tallman Water Pump (A50774)
Tallman Water Pump...
2007 Freightliner School Bus (RUNS) (TITLE) (A50774)
2007 Freightliner...
