Grading MX6 Blade Changes?
   / MX6 Blade Changes? #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
Folks -
This is my first year to do the checkup on the MX6 and I'm wondering how I should go about safely elevating the unit so I can check the blades, etc., under there. The manual shows putting it on Jackstands, but I don't think I'll be doing it that way.... :eek:
Any thoughts and best practices to share?
Thanks!
-Bob
   / MX6 Blade Changes? #2
I would raise it with the 3PH, and put three or four jackstands under there to hold it up.
What's your issue with jackstands?
My concern is that I didn't think they would be high enough for me to climb underneath and work.. is that not true?
-Bob
   / MX6 Blade Changes? #4
I use jackstands to work under my car and truck all the time, Not sure why the MX6 would be any different.
   / MX6 Blade Changes? #6
-Bob
You need the bigger jackstands. JC
Ok. I'll give it a try and see how things work out. Thanks.
-Bob
   / MX6 Blade Changes? #8
I use a 48 inch mechanical farm jack. The mower is still held by the 3 point hitch but you can raise it a little higher in the back for better clearence. If you still have safety concerns you can put blocks on the sides of the mower frame should there be an unlikely event where the 3 point hitch and jack fail at the same time.
   / MX6 Blade Changes? #9
rmonio said:
Folks -
Thanks!
-Bob
The nuts that secure the blades on my MX5 come off from the top, through an access hole on the right side of the deck. I suspect that yours do, too.
It's still a good idea to get under there and check for problems.
I plan to. I chewed up some stuff last year and want to make sure that everything looks good for the spring. ;)
-Bob
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2017 CATERPILLAR...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
KUBOTA M7060 TRACTOR (A51243)
KUBOTA M7060...
